I can get a cracked version of thatContigo wrote:Oh and yes you're right it's an unlicensed shareware version which will let you look at error codes (well most modules anyway) and I find it's enough. It's helped me out in the past anyway.
I think the license for that version is $99. So not too bad really if you want the full thing.
Stuck with VAGCOM
In descending order:
E46 M3 (fun, but common place)
TVR Sagaris (axe murderer in the wet)
Porsche 996 911 (no soul)
Porsche Boxter 2.7 (boring)
Audi RS2 (looooved it, except the bills)
Lotus Elise (fun under 60)
Audi S2 380 BHP (X2) (big bills, big hassle, but major fun)
VW Corrado VR6 (took 2 miles to stop)
neckarsulm
I wouldn't post things like that as Uwe Ross and Sebastian from Ross Tech are regular visitors to this forum.I can get a cracked version of that will post when I find.
Also without fully paid up users like me there would be no VAG COM and thus no copy interfaces and we'd all be at the mercy of the stealerships and their £100+ per hour. Ross Tech's modest fees are well worth it IMHO.
If I used a copy cable and a shareware version on the car I viewed for you, I would have seen bugg3r all apart from the first fault code, not the other 7.
neckarsulm
I stand correctedYou would have seen the fault code numbers but the description would not appear.
Point taken and my sorry for being so dumb, should know better than to post a dodge link.. I'll buy a proper copy
It's working, but it won't let ,me run the auto scan.... starts to run, picks up vin ect... after about 1 min, the car beeps from the dash and says to register on the laptop. Trying on my brothers run around Audi A4 8D Vin code. ?? how do I get just the basic codes????? as you say, want to make sure it works on shareware before I purchase. Thanks again.Contigo wrote:Is it working now? At least get it working and then get familiar with it before parting with your hard earned.
neckarsulm
I doubt a shareware one will do an autoscan
Just go into 'SELECT' then 'ENGINE' and then 'FAULT CODES'
Are you using a genuine cable?
Auto scan does not work on the shareware version.
As Neckarsulm says all you do is go into the Engine then click Fault Codes. It will show any faults in there if there are any since it was lat cleared. You can copy them by clicking copy and then paste them into Notepad or text editor. Then clear them down and go for test drive and see what Errors are in there after the run.
In my opinion that's all you really need apart from the odd recode for the instruments but once that's setup it's set.
This is a useful page
http://www.ross-tech.com/vag-com/cars/audiB5.html
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
2006 BMW M6 - GONE
neckarsulm
Can you use measuring blocks in shareware as IMHO this is the best bit of VAG COM as you can do your FATS time and measure MAF output to see roughly your BHP?
Also Coding is useful so you can program auto locking, Adapatation is useful to switch from Longlife etc
Using it as shareware is better than nothing but it really is only scratching the surface.
Also without the full fault code descriptions you'll have to look up the standard OBD description of the fault code somewhere while with VAG COM it gives you this and often a more specific description with hints e.g. 'Check DV'.
Thanks for your advice on this guys, I did manage to get NO FAULTS FOUND from my brothers run around yesterday. I too get the impression that this software is capable of allot more so will be purchasing. It's going to be handy to have in years to come and you just know as soon as you even think, there might be problem with your car the first thing your going to do is buy a licence anyway. I just need to practice with it. Didn't want to make any changes to my brother car so was being ginger.neckarsulm wrote:Can you use measuring blocks in shareware as IMHO this is the best bit of VAG COM as you can do your FATS time and measure MAF output to see roughly your BHP?
Wish there was somewhere I could try the complete version with having to be be plugged into an interface.
If you're going to make a putchase, buy the proper USB cable direct from Ross-Tech that activates the full and latest version of the software - it is the easiest way to do it and gives you full functionality.
B7 S4 Cab
B5 RS4: MRC custom remap, Milltek 100cpi cats and rear system, RS6 8-pots, H&R PCS coilovers, H&R ARBs, AWE DTS, Tanoga Shortshift, Dynaudio / Focal / Genesis / iPod audio: SOLD, and still missed. One day....
Having a good go with this VAGCOM. Can I see real time data in the form of a GUI? boost, RPM's, torque, speed, MPG ect?
Users browsing this forum: No registered users and 70 guests
