Hi guys,
A few months back I was having some throttle related issues, basically the standard ones where the consensus is diverter valves or MAF. I thought to save messing around I would buy the diverters and the MAF to make sure, this fixed the problem. A few days ago the throttle issue has came back but different this. I think last time I had a MAF issue as the power loss was more consistant but this power loss is happens around 3000-3500 rpm, the power fade then comes back. I think the diverters have gone what do you all think, also will I be able to return them to audi as they are genuine parts just bought through VAG parts?
Cheers in advance.
VAG Parts question/Diverter Valve issue (I think)
RE: VAG Parts question/Diverter Valve issue (I think)
Worth a shot in my opinion
Audi RS4 B5 in black - Stayed standard for a total of 4 weeks
Honda CBR1000RR Fireblade
KTM LC4 640 Supermoto
Have you pressure tested the DV's to see if they're at fault and not something else? You need to get a top end pressure test carried out.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: RE: VAG Parts question/Diverter Valve issue (I think)
That begs the question where do i go for a pressure test and how much would it cost???Nige_RS4 wrote:Have you pressure tested the DV's to see if they're at fault and not something else? You need to get a top end pressure test carried out.
RE: Re: RE: VAG Parts question/Diverter Valve issue (I think
Nearest place to you that I can recommend is Grizz @ unit20 (over near Liverpool) ... http://www.unit20.org
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Audi won't accept parts that were purchased from VAGPARTS, they won't even accept if they were purchased from another Audi franchise.
