Sagging Door
2.7 V6 30v biturbo - 380 bhp
gb
Sagging Door
Post by gb » Wed Dec 17, 2008 12:23 pm
I have a sagging drivers door.
When I tighten the grub screw on the top hinge it seems to fix it most of the way. Problem is the grub screw comes loose again rather quickly.
All other doors are perfect and their grub screws are tight. If anyone is able to shed light on the matter it would appreciated? Is there some way the hinge can be serviced/repaired, and if so what is involved?? Is it simply a matter of replacing the grub screw??!!
Regards,
GB from downunder
Nige_RS4
RE: Sagging Door
Post by Nige_RS4 » Wed Dec 17, 2008 12:38 pm
Can you not put some threadlock on the grub screw?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
gb
Post by gb » Thu Dec 18, 2008 1:07 pm
Thread lock could reduce the frequency of this coming loose, but I fear its only a 'band-aid' solution.
It would be good to understand what makes this one loosen while the other three stay tight without sag in the doors. :?
Regards,
GB from downunder
lengster1
Post by lengster1 » Thu Dec 18, 2008 8:14 pm
Err the most used door on the car is why it wears first at a guess,Loctite thread lock should lock the screw in but make sure you de grease the threads for it to take properly
Users browsing this forum: No registered users and 23 guests
