Not really a new topic...B5 rattle on manifold, i bought a set of nice tubular stainless manifolds for £150 on ebay. care should be taken because they dont fit very well and it has just cost me another £100 to get them modified. while the engine was out we decided to treat it to o few new parts..Cam belt kit, waterpump, silicon hoses, clutch kit, top end gaskit set and a damn good clean.
can anybody sugest any futher work before the unit goes back in
thanks
mark
B5 manifold rattle
RE: B5 manifold rattle
I suggest you throw the manifolds away unless you want pull your engine again in 5000miles time thata what happened to me
1.9TDI A6 are sh*t wrong forum
jimbo1234567
- 5th Gear
Re: RE: B5 manifold rattle
musty1 wrote:I suggest you throw the manifolds away unless you want pull your engine again in 5000miles time thata what happened to me
665 bhp + 586 lbft...
RE: Re: RE: B5 manifold rattle
It really is a case of you get what you pay for with these ebay manifolds.
For the cost of these things, couldn't the standard items be de-burred and improved?
I had similar experience with a V8 Range Rover. Apparently the thermal expansion coefficient of stainless steel is a bit excessive for use as an exhaust manifold, causing sealing and clearance problems. Also, anything that increases the temperature under the bonnet can't be a good idea, can it?
I recently bought a set of inconel manifolds from MRC I have seen
AWE,eBay,MTM and these are fair the best design for flow and reliability
jimbo1234567
- 5th Gear
the mtm ones are good for 800 hp
Users browsing this forum: Bing [Bot] and 67 guests
