Decyphering error codes
2.7 V6 30v biturbo - 380 bhp
KenM
Post by KenM » Wed May 14, 2008 11:16 am
Hi all,
Just trying to decypher a couple of error codes after a recent diagnostic.
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 63351
1 Fault Found:
01273 - Fresh Air Blower (V2)
17-10 - Control Difference - Intermittent
Have had a look on Ross tech and it comes back as: Possible Causes
Fresh Air Blower (V2) defective
Control Module for Fresh Air Blower (J126) defective
Wiring defective
Anyone translate this into english? Everything appears to be working fine? Cimate control works fine....
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Part No: 8D0 920 981
Component: B5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00899
WUAZZZ8DZ1N904644 AUZ7Z0A1786737
2 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
31-10 - Open or Short to Ground - Intermittent
Terminal 15 OK, but Terminal S not OK
Fuse(s) faulty
Wiring/Connector(s) from/to Ignition/Starter Switch (D) faulty
Again, anyone translate? Everthing appears fine.
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Part No: 8D0 035 195
Component: Radio D00
Coding: 00010
Shop #: WSC 00899
1 Fault Found:
00850 - Control Output Active; Radio Amplifier
29-10 - Short to Ground - Intermittent
Any help appreciated.
Cheers all....
Virdee Autos
Trader (Expired)
RE: Decyphering error codes
Post by Virdee Autos » Wed May 14, 2008 8:50 pm
Mat best thing to do is to erase all those faults, and then re-check in a couple of days to see what has re-appeared.
Those above faults may have occured during the life of the car, or even when at some point the battery has gone flat.
Virdee Autos ~ 07950-526592
Users browsing this forum: No registered users and 88 guests
