Rear Brake Callipers
I am going to do a brake service this weekend on my car, and I allready know that the rear callipers are a bit tight, (hopfully not seized).
Does anyone have an opinion on trying to service the callipers to free them up, or is it best poilicy to just buy a new callipers?
Not sure if servicing the calliper with release oils will potentially damage the piston seals etc.
- nickelvery
RE: Rear Brake Callipers
Are you planning on changing the brake fluid as well? If so is this an easy process or do you need a speacil tool for it?
Thanks in advance.
Nick
Thanks in advance.
Nick
The next AudiMeets event is Sunday 13th July
www.AudiMeets.co.uk
http://i82.photobucket.com/albums/j250/ ... banner.jpg
www.AudiMeets.co.uk
- boxerdogted
You can buy seal kits for them which will allow you to strip and clean them. What usually happens is the outer boot perishes and allows moisture in causing corrosion behind the seals. You can strip them down and clean up the bores of the calipers and reassemble with new seals.If the pistons are corroded and the chrome is coming of it is time for new calipers.
2001 RS4 Misano Red
Nick
I am planning to change the brake fliud as well. I usually do this after each winter.
- nickelvery
Re: RE: Rear Brake Callipers
Is it easy to do as I am planning on doing it myself soon, is the system pressurised?K2 wrote:Nick
www.AudiMeets.co.uk
www.AudiMeets.co.uk
RE: Re: RE: Rear Brake Callipers
A seal kit for one caliper only is about £12 from the dealers.......... quite alot for a couple of bits of rubber.
im pretty sure i have a spare seal kit for 2 rear RS6 calipers..ive just serviced a set im selling..
ive had the disc's skimmed and the carriers powder coated black..new seals and new backing plates..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
where does one get discs skimmed, as mine could do with that too?
Nick
No i dont think that the system is pressurised, or at least it did not appear to be when i last bled my 6 pot brembo calipers on the front.
I'm presuming that if it is, taking the lid off the fluid reservoir would release the pressure.
I would be grateful if someone post the RS4 B5 standard rear caliper assembly part numbers please.
2000 S4 Avant | Santorin Blue | 710Ns | Short Shift | R8 Replicas | B5 RS4 Brakes
- Virdee Autos
- Trader (Expired)
8D0615423D (left)
8D0615424D (right)
8D0615424D (right)
Virdee Autos ~ 07950-526592
Users browsing this forum: Bing [Bot] and 94 guests
