Rear Brake Callipers
2.7 V6 30v biturbo - 380 bhp
K2
Post by K2 » Thu Feb 14, 2008 11:49 am
I am going to do a brake service this weekend on my car, and I allready know that the rear callipers are a bit tight, (hopfully not seized).
Does anyone have an opinion on trying to service the callipers to free them up, or is it best poilicy to just buy a new callipers?
Not sure if servicing the calliper with release oils will potentially damage the piston seals etc.
nickelvery
RE: Rear Brake Callipers
Post by nickelvery » Thu Feb 14, 2008 12:27 pm
Are you planning on changing the brake fluid as well? If so is this an easy process or do you need a speacil tool for it?
Thanks in advance.
Nick
boxerdogted
Post by boxerdogted » Thu Feb 14, 2008 1:29 pm
You can buy seal kits for them which will allow you to strip and clean them. What usually happens is the outer boot perishes and allows moisture in causing corrosion behind the seals. You can strip them down and clean up the bores of the calipers and reassemble with new seals.If the pistons are corroded and the chrome is coming of it is time for new calipers.
2001 RS4 Misano Red
K2
Post by K2 » Thu Feb 14, 2008 3:22 pm
Nick
I am planning to change the brake fliud as well. I usually do this after each winter.
nickelvery
Re: RE: Rear Brake Callipers
Post by nickelvery » Thu Feb 14, 2008 4:07 pm
K2 wrote:Nick
Is it easy to do as I am planning on doing it myself soon, is the system pressurised?
boffhead
RE: Re: RE: Rear Brake Callipers
Post by boffhead » Thu Feb 14, 2008 4:15 pm
A seal kit for one caliper only is about £12 from the dealers.......... quite alot for a couple of bits of rubber.
s4woody
Post by s4woody » Thu Feb 14, 2008 5:08 pm
im pretty sure i have a spare seal kit for 2 rear RS6 calipers..ive just serviced a set im selling..
ive had the disc's skimmed and the carriers powder coated black..new seals and new backing plates..
GARTH ROAD MOT CENTRE LTD
020 83353032
K2
Post by K2 » Thu Feb 14, 2008 5:51 pm
where does one get discs skimmed, as mine could do with that too?
K2
Post by K2 » Thu Feb 14, 2008 5:55 pm
Nick
No i dont think that the system is pressurised, or at least it did not appear to be when i last bled my 6 pot brembo calipers on the front.
I'm presuming that if it is, taking the lid off the fluid reservoir would release the pressure.
par_s4
Post by par_s4 » Sat Oct 04, 2008 3:30 pm
I would be grateful if someone post the RS4 B5 standard rear caliper assembly part numbers please.
2000 S4 Avant | Santorin Blue | 710Ns | Short Shift | R8 Replicas | B5 RS4 Brakes
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Oct 04, 2008 3:49 pm
8D0615423D (left)
8D0615424D (right)
Virdee Autos ~ 07950-526592
