Max power on standard injectors?
What is about the max power that can be got out of an RS4 on standard injectors and fuel pump?
Mark
RE: Max power on standard injectors?
I say round 500bhp +-20bhp... All depends on a lot of stuf...
Best regards
Best regards
Depends on what heads, S4 heads your looking at 400bhp, but rs4 are closer to 500bhp IIRC.
Dave.
White MK2 Golf.. Slightly modified
Re: RE: Max power on standard injectors?
This is specific to RS4 type heads and inlet manilfoldHarper--D wrote:Depends on what heads, S4 heads your looking at 400bhp, but rs4 are closer to 500bhp IIRC.
Mark
RE: Re: RE: Max power on standard injectors?
on rs4 heads and inlet manifold around the 500bhp as harper-d says on s4 lower due to spray pattern
1.9TDI A6 are sh*t wrong forum
That is why i said depends on the heads to start with.MarkB wrote:This is specific to RS4 type heads and inlet manilfoldHarper--D wrote:Depends on what heads, S4 heads your looking at 400bhp, but rs4 are closer to 500bhp IIRC.
Dave.
Blue_Thunder
- Top Gear
Do the RS4 heads allow you to run much more aggressive timing?
I'm interested to know what makes the RS4 more powerful that the S4 using the same injectors and fuel pump, as Doug had mentioned in another thread referring to the difference between RS4 and S4 engines that
Doug_S2 wrote:internals are different but only stronger - nothing will give better performance.
Re: RE: Re: RE: Max power on standard injectors?
It's the heads, cams and inlet that makes all the difference. These push the power further up the rev range, probably due to them being larger so aren't so efficient at lower rpm.Blue_Thunder wrote:Do the RS4 heads allow you to run much more aggressive timing?
I'm interested to know what makes the RS4 more powerful that the S4 using the same injectors and fuel pump, as Doug had mentioned in another thread referring to the difference between RS4 and S4 engines thatDoug_S2 wrote:internals are different but only stronger - nothing will give better performance.
Mark
- Virdee Autos
- Trader (Expired)
RE: Re: RE: Re: RE: Max power on standard injectors?
Thats what makes 90 odd bhp?!
Virdee Autos ~ 07950-526592
Re: RE: Re: RE: Re: RE: Max power on standard injectors?
It's what puts a K04 RS4 about 50bhp ahead of a K04 S4 when the rest of the exhaust, downpipes and intercoolers etc are the same. All in the heads, cams and inlet, IMOR33V-Spec wrote:Thats what makes 90 odd bhp?!
Mark
- Virdee Autos
- Trader (Expired)
RE: Re: RE: Re: RE: Re: RE: Max power on standard injectors?
Ok fair enough
