Hello!
As the power is back now with changing the MAP, I did some VAG-COM block logging and highest figures are like this:
@ ~ 6000 RPM -
1. MAF - 330 g/s;
2. Boost - 2200 mbar;
3. EGT - 945C all the way from 2000-7000;
4. Outside temps around 15 degrees celsius.
I will show the logs in the evening when I'll be at home. The logging was done in 3rd gear. After using MRC online FATS calculator - it came out for 4.3 sec.
Are these normal figures for stock RS4? As I red in the forum, normal MAF figures for stock RS4 is 280-300 g/s. Don't know about the boost....
Please can someone tell Your opinion or at best show some stock RS4 logs?
Thanks in advance!
VAG-COM logs for stock RS4
Audi RS4 Daytona grey w/ 2x RS6/TTS hybrids, 8.5:1 CR, front mount IC with 2xinlets&2xoutlets, SPEC Stage 5 feramic clutch, 2 x 3in DP's, 2x 3in Aeroturbine res, 3.5in cutout, 790cc inj's,MOVIT 380mm f/brakes,Porsche 911 GT2 6-piston calipers....
Ex Audi S4 w/GT30R
Ex Audi S4 w/GT30R
Re: VAG-COM logs for stock RS4
no replies ? I count on You, guys!
Ex Audi S4 w/GT30R
Ex Audi S4 w/GT30R
RE: Re: VAG-COM logs for stock RS4
Post the full log. Without it it's hard to see whats going on.
Mark
Users browsing this forum: No registered users and 85 guests
