How to tell if the engine is knackered ??
2.7 V6 30v biturbo - 380 bhp
soapy_g
Post by soapy_g » Mon Oct 08, 2007 12:31 pm
Hi guys
Having bought my RS4 a few months ago, in Hong Kong, i am increasingly troubled by the wear and tear of the car.
The car is quite quick although seems to run out of steam at the top end, but does have a stuttering throughout the rev range.
I bought VAGCOM and performed some logs. The fault scan shows secondary air injection system - insufficient flow codes on both banks ; and EGT short to ground error codes.
The garage i took it to said they thought it might have been clocked ( how the **** that can be done on a digital read out ...) as the general wear on the engine is high !
My recent VAGCOM logs show low peak MAF of 207 ( compared to 280/300 quoted as stock RS4) , requested boost of peak 2,100 mbar ( which seems very high) and actual boost of peak 1,400 mbar ( which seems high in absolute terms but low compared to requested boost above ).
My concern is that the entire thing is verging on a blowout, as it is operating at inflated and unsustainable boost, with massive leaks from the system. If it has been remapped to deliver high boost, that might be masking the otherwise leaking/knackered turbos/engine ?
Can anyone help with suggestions on what further needs to be checked to detarmine if the entire engine including turbo's has been well shagged in a previous life , and that i could be facing an entire rebuild ???
Does a compresssion test or pressure test assist with this problem ?
or i am just paranoid
GULP :?
RSpimp
RE: How to tell if the engine is knackered ??
Post by RSpimp » Mon Oct 08, 2007 12:38 pm
i had same problem with top end power loss .. turned out to be dump valves ! if it is that go for the uprated alloy piston type instead of the plastic "oem" ones that are fitted ! they are known to perish and fail .
S4power
Post by S4power » Mon Oct 08, 2007 1:46 pm
You have PM!
Thomas / RS4 Sport By quattro GmbH / S3-08 / RS4 Limo By TECS
Nige_RS4
Post by Nige_RS4 » Mon Oct 08, 2007 2:02 pm
It only takes something as simple as a failed MAF, Bypass Valve or EGT sensors to give the errors you are experiencing. VAG-COM recorded boost is misleading to the uninformed as it includes 1.0 Bar of atmospheric pressure, so you are only showing 1.1Bar peak, which AFAIK is std. As stated above, replace both bypass valves (my advice is to buy OEM 710N valves as fitted to the S3/TT 225), then clear the codes and re-check MAF output. Also, check plug type and condition.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
soapy_g
Post by soapy_g » Mon Oct 08, 2007 5:21 pm
Aha, thanks for the absolute point - :oops: I am going through a massive learning curve here from pretty much nil !
I am trying to get my local mechanic to look at the points you raised, thanks Nige.
quattrokid1
Post by quattrokid1 » Mon Oct 08, 2007 5:53 pm
I bet there isnt many RS4's in Hong Kong!!!! we wont be seeing you often in the spotted forum then!
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
soapy_g
Post by soapy_g » Mon Oct 08, 2007 6:21 pm
Interesting point, although i have been so frustrated with tuners here that i have contemplated shipping the car back to Banbury for peace of mind ( then using it in greenock, somewhat closer to you than my current location :D )
cheers
soapy
