RS4 Alignment numbers/spec
I am getting an RS4 suspension installed on my S4 and I wanna do a 4-wheel alignment, but they don't have the right alignment numbers for RS4 to do it properly, all they have is the S4 numbers.
Anyone's got those numbers to share please?
Thanks!
Thanks!
Hi there just had my RS4 alligned and these are the spec's.also try (B6/B7) avant sport suspension A4/S4/RS4 quattro:2001-
Front
left specified range right specified range
Camber -1deg35' -0deg22' -1deg35' -0deg22'
toe 0deg05' 0deg15' 0deg05' 0deg15'
turning angle diff -1deg36' -0deg36' -1deg36' -0deg36'
toe raised 0deg07' 0deg21' 0deg07' 0deg21'
cross camber -0deg30' 0deg30'
total toe 0deg10' 0deg30'
cross toe raised -0deg10' 0deg10'
Rear left spec range right spec range
camber -1deg50' -0deg50' -1deg50' -0deg50'
toe 0deg08' 0deg15' 0deg08' 0deg15'
total toe 0deg15' 0deg30'
thrust angle -0deg10' 0deg10'
hope this helps, deg= degree's '=minutes
Front
2002 Noggy RS4,AP 6 pots,Revo,H&R big arb's,milltek.
Are you sure these numbers are correct? If so, the car has to be setup with positive Toe (toe out)...p.binks wrote:Hi there just had my RS4 alligned and these are the spec's.also try (B6/B7) avant sport suspension A4/S4/RS4 quattro:2001-
Front
I aligned my S4 with RS4 suspension and they set the toes at 0.0 and it doesn't handle well... but still not sure if it makes sense to toe out the car....
Anyone has any ideas regarding this?
Thnx
simon_golf_tt
Users browsing this forum: No registered users and 94 guests
