partnumbers RS6 Brakes on RS4
2.7 V6 30v biturbo - 380 bhp
zeke
Post by zeke » Fri Dec 09, 2005 7:11 pm
[quote]
But now im wondering to get the RS6 discks shuld be no problem?
THANKS!
/Jimmy Särås
Yea that will be good to know, becausde de RS4 disk are 360mm vs 365mm of the RS6. The caliper of the RS6 are bigger than the RS4 disks around 2mm up and 2mm down, so a part of the brake pad doesn´t touch the disk.
Regards
CliveH
Post by CliveH » Tue Jan 03, 2006 4:02 pm
Although the RS6 discs are obviously ideally suited to the RS6 calipers, they will go straight onto the RS4 discs.
I have a spare set if anyone is interested...
http://www.rs246.com/index.php?name=PNp ... ic&t=51413
Clive
jose3000
Post by jose3000 » Mon Jan 16, 2006 12:53 am
helo there. I'm new on this forum. a have an audi s3 evo 225ps. MY question is can i put these mga brakes RS6 on my s3 whitout big changes?
cumps
r4fdud
Post by r4fdud » Tue Sep 05, 2006 7:35 pm
does anyone have one of these set upd for sale including the discs??
easto
Post by easto » Fri Jan 26, 2007 3:53 pm
What kind of cost are we looking at and what kind of breaking improvements do they provide.
I am going to require some new discs/pads all round very shortly and may as well look at the options of doing this.
Misano RS4 (B5), MRC Custom Map , Quick shift, Milltek Exhaust and Downpipes, B7 Front Brakes, B7 19's
EggMan
Post by EggMan » Thu Jun 28, 2007 9:22 pm
Hi Guys,
New to the forum was hoping I could pick your brains over a few questions I have..........
I have recently purchased an RS4 B5 with the B7 Discs and calipers, only thing is under any breaking force the front end shudders much like you would expect from warped discs has anyone else suffered these problems? Is there anyway to sort this out? On inspection the discs, pads and calipers all appear to be in good condition although the previous owner said the brakes have not been on there for a long time. And I obviously cant comment on if they were bedded in properly.
Do I need to replace the hub for the B7 type to hold the disc carrier more true perhaps?
Many thanks for your help!
docurley
Post by docurley » Fri Aug 24, 2007 2:30 pm
Came across this on ebay that might be of intrest to some.
Translation
1 sentence steel flex brake hoses for the AUDI RS4 (B5) with the RS6 brake 365 x 34 mm at the front axle and at the rear axle series
Flex some crucial advantages offer steel to brake hoses. The pressure build-up in the brake system is passed on directly and without delay, developing when braking, to the brake calipers. This shortens the response time of the brake assembly and thus the braking distance. The steal-encased teflon brake hoses are simply replaced against the standard rubber hoses.
with partial appraisals
Freight charges Germany far 6.50 €
ebay link
quattrokid1
Post by quattrokid1 » Sat Aug 25, 2007 3:58 pm
my pal has a set of SL55AMG front calipers and discs wth pads, would these fit straight onto the B5 RS4 without mods please. I have found that the AMG calipers use 334mm discs.
Just wondering if these would be of use on an RS4
t.v.m
Misano red B5 RS4 710 D/V's SERVICED BY EL GRIZZMO:).... Wife's !!
Tornado red WR quattro :):)
UrS4 saloon auto:) resurected by Unit20
Audi S3 8L Imola yellow
Audi B6 S4 Cabrio SOLD :( :(
Audi 100 2.2E SOLD
Audi 80 cabrio 2.6 V6 (SOLD)
Audi 90 quattro SOLD
team_soy
Post by team_soy » Tue Feb 19, 2008 6:07 pm
i will be trying this set up. As soon as i can find some 18's to go with it lol
Ruggu
Post by Ruggu » Tue Jun 17, 2008 9:38 am
Doing the B5 RS4 brake upgrade to B7 should only be done one way, that is the right way. Whilst the caliper will fit onto the existing mount (Oh and you do have to cut away a small section of the backing plate to accomodate the bigger caliper) the disc are not up to the job, hence will result in warping! The B7 RS4 brakes are designed to dissipate heat and dust far better than the regular vented B5 discs. As for the pipe, it passes through a holder which prevents the actual connection from vibrating loose. Do it the right way guys!
s3170659
Post by s3170659 » Mon Dec 08, 2008 10:55 am
Actually, is the RS6 caliper same as the B7 RS4 caliper which the part # are different??? also the disc??
RS6:
4B3 615 107
4B3 615 108
RS4:
8E0 615 107
8E0 615 108
Disc:
8E0 615 301
4B3 615 301
both 2 piece floating disc??
2dogsjohn
Post by 2dogsjohn » Tue Aug 25, 2009 12:25 pm
what is the difference between the above callipers and these part numbers if anyone happens to know every audi part no. 8E0 615 107 8E0 615 108
2dogsjohn
Post by 2dogsjohn » Tue Aug 25, 2009 12:30 pm
sorry didnt see last entry.deeerrrrr! but assuming it makes no difference which one you fit as about to buy ones with part no i just mentioned. thanks
CliveH
Post by CliveH » Tue Aug 25, 2009 12:39 pm
One is the left caliper and the other is the right, but cant tell you which is which, sorry.
The RS6 C5 and RS4 B7 calipers are identical in all respects with the exception that the RS6 calipers have an additional bar (for strength I think) on one side of the caliper.
The RS6 and RS4 discs are identical in size but the hats are different resulting in a different offset. Consequently, the RS4 B7 discs bolt straight on to a B5 S4 or RS4 (with the above calipers), but the RS6 discs will need a modified caliper mounting bracket.
Finally, the RS4 B7 discs are 'cross drilled', as are the RS6+ discs, but the RS6 (plain Jane) discs are solid (but vented).
Clive
Emp2k
Post by Emp2k » Thu May 20, 2010 12:41 am
interesting. :)
So one could then buy calipers and pads first then buy discs when existing discs need to be changed? Do i need the caliper carrier from the RS4 b7 to fit RS4 B7 discs?
Users browsing this forum: No registered users and 94 guests
