thanks guys I thought as much and makes sense Doug mentioned it was abit noisey on its last health checkphilipwalker wrote:As suggested above it is designed to dilute the exhaust emissions on cold start-up. It pumps fresh air into the exhaust. If there is a restriction or a sec air system pipe off it will throw up a code, as its emission relaited it will put the ecu light on as well.
New pumps are a bit pricy so look around for a s/hand one. Ask the servicing dealer to check that the pump unit faulty rather then a open circut.
Hi dougDoug_S2 wrote:We remove th esecondary air injection from a lot of rs4s and 1.8ts and can disable the ecu checks for it.
Users browsing this forum: No registered users and 40 guests
