Hi there. Just wondering if anyone has come across the following problem. In heavy rain my RS4avant can get very noisy , particularly if you hit a deep puddle. Is it sucking in water or is it simply something to do with the exhaust?
I dont want to bend any rods so please help
(PS the car is bog standard.)
Thanks in anticipation
Mike
Gurgling in the wet?
RE: Gurgling in the wet?
Same here. I sometimes get that symptom after a longer drive in very wet conditions. Then when I start to engine brake, there is the noise. Like the exhaust touching the body -which I suspect it does. Maybe wet causes the pipe to heat / cool unevenly, making for a bending effect in the exhaust. That causes it to touch the body? Don't know.
Has anyone else had this symptom, or better yet, solved it?
- RS4inGermany
- 1st Gear
Users browsing this forum: No registered users and 112 guests
