yellow? engine warning light?
its been coming and going the last few days. Vagcom (got someone to do it) said something about "Coolent System" and to check "DTC memory" now the light is just on, my engine temp just stays in the blue and never goes up. What could be the fault and is it gonna cost alot? my washer pump is also gone and only had the car less then 2 months
2001 Audi RS4 Avus
2003 Range Rover Vogue V8 Java Black
RE: yellow? engine warning light?
Sounds like it has lost water, but it would throw up a DIS Low Coolant aswell.......... if it is staying in the blue, your thermostat is stuck open, mine goes straight to the middle, and never moves.........
Sould just be the coolant temp sensor. probably worth changing it to see if it makes a difference - only cost about £8 and easy to locate and change out. If it's never been changed then the original temp sensors were more temperamental than the ones that replaced them which had better tolerances built in.
2001 Avus Silver RS4, APRacing 6pots - Gone, but not forgotten
Search for the after run mod as there will be a part number to help you order this sensor.
But if you follow the "after run mod" route you will get a better cooling onto the turbos when you turn the car off as the new sensor will trigger your secondary water pump at lower temp when you turn off the car.
This will Fix the car and get you an up grade we hope!
Users browsing this forum: No registered users and 93 guests
