Boost lack : 0.5b(7.25psi) instead of 1.2b (17.40psi) on RS4
Froggyfreddy
I was surprised by the feeling of a lack of pressure on my new RS4, so i took the pressure with a gauge.
Has somebody already been confronted to this kind of problem on S4 or RS4 biturbo?
No doubt 3 issues :
- CHECK ENGINE that put the system in safety control and reduce to 0.5bars (7.25psi)
- Leak in the pressure system
- one turbo out
Thanks to help
Fred
No doubt 3 issues :
- one turbo out
Thanks to help
Fred
911TT_STEVO
RE: Boost lack : 0.5b(7.25psi) instead of 1.2b (17.40psi) on
Bloody Hell! This is bizarre! The last time I was on I mentioned about this that some of you guys might have boost leaks and not know (this happened to me) I was reading 0.5 constant and didn't think anything of it until I had a re-map and it was still at 0.5. If it's lack of boost the first thing you should check is that all hoses are connected (also at DV's) as a hose could be leaking or even slipped off, it's as simple as that!
Has your car gone into Limp mode?
If it has, I would doubt it was a leak!!!
Froggyfreddy
Re: RE: Boost lack : 0.5b(7.25psi) instead of 1.2b (17.40psi
Thanks, but no limp mode911TT_STEVO wrote:Bloody Hell! This is bizarre! The last time I was on I mentioned about this that some of you guys might have boost leaks and not know (this happened to me) I was reading 0.5 constant and didn't think anything of it until I had a re-map and it was still at 0.5. If it's lack of boost the first thing you should check is that all hoses are connected (also at DV's) as a hose could be leaking or even slipped off, it's as simple as that!
RE: Re: RE: Boost lack : 0.5b(7.25psi) instead of 1.2b (17.4
have u had the codes checked with VAG-COM..that will give u the sort of info u mite need..could be a MAF sensor or EGT sensor,s or like u say a poss boost leak..where about are u and look in the VAG/DTC section in the sticky and see if a member is close so u can meet and get it checked out..then your,ll no what way to turn..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Froggyfreddy
Froggyfreddy
what are the fault codes..and have u had the basic settings done or had the throttle position reset..
020 83353032
020 83353032
Froggyfreddy
Froggyfreddy
Users browsing this forum: Bing [Bot] and 120 guests
