Boost lack : 0.5b(7.25psi) instead of 1.2b (17.40psi) on RS4
2.7 V6 30v biturbo - 380 bhp
Froggyfreddy
Post by Froggyfreddy » Mon Mar 13, 2006 1:28 pm
I was surprised by the feeling of a lack of pressure on my new RS4, so i took the pressure with a gauge.
Has somebody already been confronted to this kind of problem on S4 or RS4 biturbo?
No doubt 3 issues :
- CHECK ENGINE that put the system in safety control and reduce to 0.5bars (7.25psi)
- Leak in the pressure system
- one turbo out
Thanks to help
Fred
911TT_STEVO
RE: Boost lack : 0.5b(7.25psi) instead of 1.2b (17.40psi) on
Post by 911TT_STEVO » Mon Mar 13, 2006 1:53 pm
Bloody Hell! This is bizarre! The last time I was on I mentioned about this that some of you guys might have boost leaks and not know (this happened to me) I was reading 0.5 constant and didn't think anything of it until I had a re-map and it was still at 0.5. If it's lack of boost the first thing you should check is that all hoses are connected (also at DV's) as a hose could be leaking or even slipped off, it's as simple as that!
Has your car gone into Limp mode?
If it has, I would doubt it was a leak!!!
Froggyfreddy
Re: RE: Boost lack : 0.5b(7.25psi) instead of 1.2b (17.40psi
Post by Froggyfreddy » Mon Mar 13, 2006 1:55 pm
911TT_STEVO wrote:Bloody Hell! This is bizarre! The last time I was on I mentioned about this that some of you guys might have boost leaks and not know (this happened to me) I was reading 0.5 constant and didn't think anything of it until I had a re-map and it was still at 0.5. If it's lack of boost the first thing you should check is that all hoses are connected (also at DV's) as a hose could be leaking or even slipped off, it's as simple as that!
Thanks, but no limp mode :?
s4woody
RE: Re: RE: Boost lack : 0.5b(7.25psi) instead of 1.2b (17.4
Post by s4woody » Mon Mar 13, 2006 3:15 pm
have u had the codes checked with VAG-COM..that will give u the sort of info u mite need..could be a MAF sensor or EGT sensor,s or like u say a poss boost leak..where about are u and look in the VAG/DTC section in the sticky and see if a member is close so u can meet and get it checked out..then your,ll no what way to turn.. :thumbs: :redrs4:
GARTH ROAD MOT CENTRE LTD
020 83353032
Froggyfreddy
Post by Froggyfreddy » Mon Mar 13, 2006 7:31 pm
after checking, it was coming from one of the two dumpvalves. So i ordered 2 forge motosport ones today !
Froggyfreddy
Post by Froggyfreddy » Fri Mar 17, 2006 11:33 pm
I did change the dump valves and did erase faults, i had 14psi instead of 20 psi (as it has been remapped) and the system came into fault .
I 've got 0.5bas back :(
s4woody
Post by s4woody » Sat Mar 18, 2006 2:33 am
what are the fault codes..and have u had the basic settings done or had the throttle position reset..
020 83353032
Froggyfreddy
Post by Froggyfreddy » Sun Mar 19, 2006 9:43 am
s4woody wrote:what are the fault codes..and have u had the basic settings done or had the throttle position reset..
The error fault is :
"mélange (air/petrol admixture) too poor"
Froggyfreddy
Post by Froggyfreddy » Sun Mar 19, 2006 9:44 am
I did order a MAF sensor BOSH to AUDI.
I hope this is coming from it.
fred
