I bought a AWE boost gauge.
Where should i pick up the boost pressure to get it on the gauge?
Fred
boost pressure : where to pick?
RE: boost pressure : where to pick?
take it from the small rubber hose that goes to the fuel pressure regulator.. as u look at the engine its on the right side just buy the expansion bottle..it sit on the fuel rail and is usually silver.. just cut it and put the T piece in line then plug the gauge hose to it and that shud do the trick..didnt it come with instructions ??
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
Make sure you get a good tight connection when you put it all back together Freddy - you dont want any nasty air leaks...
Clive
Froggyfreddy
Users browsing this forum: No registered users and 151 guests
