This is what awaits you once you have removed the front bumper and plastic air duct to the radiator.
Upon removing the radiator, I discovered that there were 3 water inlet/outlets so I had a local radiator repair shop fabricate me a 20mm equal T with flared ends which enabled me to make the join.
Unfortunately, the hose from the secondary air pump to the air filter housing passed right across the air trumpet inlet. A trip to my local VW truck spares found me an unrelated but twisted hose that I cut to suit and which then routed the pipe away from the air trumpet. My car had already had the air flap removed.
I then attached a 1 metre length of collapsible trunking to the inlet trumpet and routed this to the front, finishing it off with the top of a funnel, cut and taped to suit.
It was a real pain to reassemble everything because the plastic air duct was previously mounted to the radiator. Also, with the new ducting in place, everything is a bit squashed but aided by plenty of cable ties, I got it all back together.
Thus my car now has a cold air inlet feeding a JHM silicone air intake, through a devaned, ported and polished inlet manifold, then exiting through a custom s/s exhaust with 200 cell sports cats. Should be interesting. Next step is to find a nice fine day and take some air flow readings to see how it compares to stock.
