Exhaust rattle on cold start
4.2 V8 32v FSI - 444 bhp
S4WON
Post by S4WON » Fri Oct 16, 2015 8:36 am
Hard to describe the noise, but its like a tin rattle from exhausts on cold start.
Only lasts bout 30 sec then clears. Doesnt do it on warm. Ive found a few threads about it, some say thats just the way it is, some say they had bits changed.
Anyone had personal experience?
Is a 14 car with 9k
Cheers!
Brooner
Re: Exhaust rattle on cold start
Post by Brooner » Fri Oct 16, 2015 8:49 am
mine is 2013 always is a bit rattly from cold but as you say less than 30 seconds and its gone personally nothing to worry about as it seems to be normal
carsarecool
Post by carsarecool » Fri Oct 16, 2015 10:36 am
Brooner wrote:mine is 2013 always is a bit rattly from cold but as you say less than 30 seconds and its gone personally nothing to worry about as it seems to be normal
Mine's the same...
marc1
Post by marc1 » Fri Oct 16, 2015 12:12 pm
Probably the exhaust valve flap. Get your ear close and see if it's present on one side or both. Apply something like WD40 (or better alternatives) to the valve after you've checked and see if it still happens the next day. If it's gone away, then you know the cause. If you have warranty still, then you'll be able to get the dealer to resolve (or supplier if it's an aftermarket product).
S4WON
Post by S4WON » Fri Oct 16, 2015 12:31 pm
Thanks gents. Still have warranty and first service due, will get it sorted then
RossDagley
Post by RossDagley » Fri Oct 16, 2015 12:58 pm
Likely passenger side back box heat shield. Known to rattle.
Previously:
marc1
Post by marc1 » Fri Oct 16, 2015 1:02 pm
Yeah, that too and easier fix!
Brooner
Post by Brooner » Fri Oct 16, 2015 1:02 pm
any fix?
marc1
Post by marc1 » Fri Oct 16, 2015 1:18 pm
To the heatsheild?
RossDagley
Post by RossDagley » Fri Oct 16, 2015 1:23 pm
Brooner wrote:any fix?
Heatshield just needs bending differently normally - mine was rattling against the underside of the boot floor.
Might be as simple as a stone between the heatshield and the body of the car. Had a few of those also.
Previously:
Brooner
Post by Brooner » Fri Oct 16, 2015 1:47 pm
thanks will check it out see if it is this
rspj
Post by rspj » Fri Oct 16, 2015 5:18 pm
Mine do also it. Goes after minute or so and all ok after big rush of air on start up its on most audi
rs4 b8 Suzuka, grey 14
Rallyz
Post by Rallyz » Sat Oct 17, 2015 6:46 pm
As I understand it, the start up rattle is pretty normal, it's to do the emission regs. My 2012 one does the same.
marc1
Post by marc1 » Sat Oct 17, 2015 8:15 pm
Depends what's rattling, surely?
S4WON
Post by S4WON » Sat Oct 17, 2015 8:48 pm
I have no idea what it is, is booked in on the 27th, will let u guys know what they say mine was
