Spigot Rings - Wheel wobble and vibrations
JRC1
Post by JRC1 » Tue Jul 29, 2025 10:40 pm
Hello
Bit of a random one, but hopefully someone can help.
I have been experiencing wheel wobble and vibrations throughout the car (seats) mainly at 65-75mph.
I have had almost everything on the car checked - brakes, driveshafts, cv boots, bushes/mounts, spacers, wheels, tyres. I've even had road force balancing carried out yet the issue remains.
A very helpful chap who undertook the road force balancing brought to my attention, however, that it appears the centre bore of the wheel is not sitting completely true on the hub - there is (very minimal) movement when mounting the wheel on the hub. He suggests that this is likely a result of multiple refurbs of the wheels and that the centre bore has been enlarged/worn down slightly, resulting in this play.
He says that spigot rings will resolve this issue as they centre the wheel perfectly on the hub.
I have read that the OEM hub size for the B7 RS4 is 57.1mm. Through the multiple refurbs, this, I am told, may have widened slightly to say 57.5mm or 58.1mm (for example).
So, if my wheels are now 58.1mm centre bore due to refinishing and my hub is 57.1mm, I'd need 58.1 → 57.1 spigot rings.
My questions are:
a) has anyone experienced anything similar to this before?
b) how do I know what size spigot rings I'd need? Do I need to measure the 'new' centre bore diameter of each wheel? I can't understand how I'd be able to source spigot rings in such bespoke sizes say one wheel is now 57.4mm and another is 57.9mm - how would this work?
Appreciate any advice.
QuRace
Re: Spigot Rings - Wheel wobble and vibrations
Post by QuRace » Wed Jul 30, 2025 6:24 am
One step at a time... I'd start with actually measuring things. What's the diameter of the hub, what's the diameter of the bore that's supposed to sit on the hub. Also, are both still round/concentric or not. If a refurb played a role here (and I personally have never heard of such a thing happening...), e.g. through incompetent blasting w/o covering such mating surfaces, the mentioned rings might actually not be able to solve your problem (should it turn out to BE your problem). Just my 2 cents...
JRC1
Post by JRC1 » Wed Jul 30, 2025 1:06 pm
Thanks. Sounds like some sensible next steps. I have been advised to measure the outer diameter of the car’s hub flange, the inner diameter of each wheel’s centre bore and request that a garage uses a digital Vernier caliper or micrometer to do this. So this sounds in line with what you are suggesting.
I don't have this equipment at home but will request my VAG garage do it for me when the car is next there.
If it isn't down to a refurb (the wheels have probably had 5-7 refurbs in their life), then what else could be causing this mismatch of size? Can hubs change in size, even slightly, and can the bore of the wheel change in size/shape through other scenarios that have nothing to do with a refurb?
It's a interesting (and bloody frustrating) one, but hopefully have now narrowed the issue down to the wheel or hub. I was worried that it could have been something more drastic like the steering rack at one point.
Users browsing this forum: Google Adsense [Bot] and 78 guests
