Anyone need replacement intake flap actuator linkage parts?
Wavey Dynamicist
Post by Wavey Dynamicist » Fri Mar 15, 2019 6:37 pm
I suspect mine has failed or is on it's way so i'm gonna design up some replacement collar & linkage parts to be machined from aluminium. The problem seems to be that the stock plastic parts wear with time and some play develops in the system which the actuator doesn't like.
To be clear it'll be both the linkage arm and the collar which fits over the shaft (if i can figure out how to remove the stock part!)
Would anyone else be in the market for this if i make it available?
2007 RS4 Saloon; Mugello Blue
coffey555
Re: Anyone need replacement intake flap actuator linkage parts?
Post by coffey555 » Sat Mar 16, 2019 2:03 pm
Yes, I still run with my inlet flaps so yes, if you start making up longer lasting sets I would be interested.
Misano Red RS4 B7 Avant
JamesBaby
Post by JamesBaby » Sat Mar 16, 2019 3:07 pm
I’m a new owner but I had a similar thing on my R32. So I’d be interested too.
James1984
Post by James1984 » Sat Mar 16, 2019 3:49 pm
Is this the same part that 034 motorsport sell?
Wavey Dynamicist
Post by Wavey Dynamicist » Sun Mar 17, 2019 11:26 am
1/2 of the kit would be yeah.. The issue with theirs is that it still has to match the stock plastic collar on the shaft, if the collar is worn and you only put a new linkage on, you'll still get play in the system which defeats the object. You also then have the added problem that the new metal linkage would then accelerate the wear on the collar.
What I'm doing is developing both matching parts to create a more robust fix - just got to do a little more investigation into how to remove the stock plastic collar from the flap shaft and it'll be good to go.
I'll keep you guys up to date. Thanks for feedback.
Mike-W
Post by Mike-W » Sat Jun 08, 2019 10:55 am
Late response, but as a recent new RS owner I’d be interested if you do fabricate them. Have you progressed the development of these?
donsounds
Post by donsounds » Tue Nov 19, 2024 4:45 pm
I would also be interested in these. My RS4 has been sitting in the garage since a month trying to find a good quality replacement...
beckford21
Post by beckford21 » Tue Nov 19, 2024 6:29 pm
Thread is over 5 years old...
Wavey Dynamicist
Post by Wavey Dynamicist » Wed Nov 20, 2024 11:34 pm
Well, i appreciate you guys digging this one up. The arms are actually complete and sitting on our computer. my EPC light hasn't returned and other projects came in and they got parked, but the next step would be to get them fabricated and verify they're the correct fitment to get them signed off for production.
If anyone wants to try them out and help me sign off the dimensions, i'd be happy to give you a development set for the cost of fabrication.
Reach out if you're interested and we can get it rolling.
donsounds
Post by donsounds » Fri Nov 29, 2024 4:50 pm
Image[/img]Thanks!! But I was lucky to find a local guy that did these. But only the right side one...It is currently being installed...
viga0723
Post by viga0723 » Tue Jul 29, 2025 1:20 am
Can I buy intake flap actuator linkage parts?
Users browsing this forum: Majestic-12 [Bot], NickvRS4 and 78 guests
