broken chain tensioner guide
2014audis8
Post by 2014audis8 » Sat May 24, 2025 4:08 am
So I broke my valve tensioner guide. Chain still seems to be tight around the tensioner and gears.
What are the chances that it jumped timing? Is it like 100% if the guide breaks the chain jumps?
Also has anyone had luck just replacing the guide itself and not the whole tensioner?
Re: broken chain tensioner guide
Post by Shoppinit » Sat May 24, 2025 9:44 am
I doubt it would have skipped a link.
Some useful info here:
Mɐʇʇ wrote:
Thu Feb 13, 2025 4:17 pm
This is the correct part, as fitted to my old RS6:
https://www.autodoc.co.uk/vaico/12246760
And I think this is the other side:
https://www.autodoc.co.uk/vaico/12246761
This was the thread I did on them: viewtopic.php?f=2&t=133688&p=974425
I also replaced the shoes on the adjuster I didn't replace and all worked well. I didn't like the blauparts adjusters, I used the ones Nobby has also used. Can't remember why I didn't like the blauparts ones, now.
Post by Shoppinit » Sat May 24, 2025 9:50 am
2014audis8
Post by 2014audis8 » Tue Jun 24, 2025 1:45 pm
so I originally took off the wrong side (bank 1), put that all back on then worked on bank 2, got the chain tensioner replaced and everything put back together.
Now Bank 1 valve cover is leaking. I took it off again, double checked everything was cleaned, put back in and torqued down properly and it is still leaking.
I replaced the PCV and it didnt help.
Has anyone else had a lot of trouble getting the valve cover to stop leaking? I am assuming the gasket is just not seated correctly but it is a huge pain to get off and on in the engine bay.
Just wondering if anyone else had issues with cover leakage and what ended up being the problem?
Users browsing this forum: 111marc111, asgor, ChrisA, Google [Bot] and 96 guests
