Any help much appreciated
Thanks NickTechNick wrote:@TOPMAN may be able to assist
Hi White Six!Weiß-sechs wrote:So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Yes you can, I did this job a couple of months ago.allroadadi wrote: ↑Sun May 04, 2025 5:12 pmWait, you were able to remove the intake manifold without removing the front end?![]()
allroadadi wrote:Wait, you were able to remove the intake manifold without removing the front end?
TOPMAN wrote:allroadadi wrote:Wait, you were able to remove the intake manifold without removing the front end?
You most certainly canJust unbolt and it will pull forward enough to get the job done
Regards
Craig
Ooh, that looks sexy CraigTOPMAN wrote: ↑Sun May 04, 2025 10:15 amHi White Six!Weiß-sechs wrote:So, the inevitable has happened (after racking over 190K miles). Perished plumbing under the the inlet manifold. Obviously, all parts required are NLA from TPS...just wondering if any of you guys have replaced these lines recently & manged to find them? Hoping to do the lot while we're in there including the after run pump if poss. Part numbers gratefully received too.
Looks like you have a POPPED SJP (suction jet pump). An increasingly common failure these days.
Looks like you’ve done the hard work already, how can I help? What do you need?
Regards
Craig Barlow
Thank you bud
They are in SwedenWeiß-sechs wrote: ↑Mon May 05, 2025 6:42 pmThank you bud![]()
Shame they're Stateside & not Europe but when needs must...
Users browsing this forum: asgor, Google Adsense [Bot], Majestic-12 [Bot], Weiß-sechs and 67 guests
