Dam slight knock
Dam slight knock
Ok got this dam slight knock on when setting off and coming to a stop. Even when I turn slightly. Going over bumps and normal driving it's absolute fine. Only when I stop or set off
It's in kw coilovers so it's not the DRC
Had all the arms changed so they ate new checked everything is tight inc the suspension top mounts
Re: Dam slight knock
Ive had exactly the same issue. (running kw v3)
replaced all the arms etc and still had it. its settled down in a few months.
thought it could be the top mounts, I think half of it was a loose undertray and also pads in the caliper.
It's just wired got it booked in this week at the garage to have a look. Nothing is loose that i can see. So will see what happens
One thing to note.
When i had all the front arms replaced they didnt use new bolts initially. This caused a clunk going from forward to reverse.
squeaking is top mounts.
I had a rattle that i thought was the suspension and after months of fettling it turned out to be the dash panel under the bonnet.
oh is it through the fotwell?
AndyBrad wrote: ↑Tue Apr 29, 2025 8:47 amOne thing to note.
It came with all new nuts and bolts etc, the garage still could not find anything loose
ah. replace the lower inner bolts and torque to spec. Thats what solved mine.
yea thats what helped with mine. The bolts were stretched.
Users browsing this forum: IshyB and 31 guests
