Petrol / Help / VCDS
cover99
Re: Petrol / Help / VCDS
Post by cover99 » Sun Feb 02, 2025 12:13 pm
Morning. I bought the sensor through E-Bay as a Genuine OEM. It was listed for a golf R32 but the same part number as ours. It looked legit as it had the audi rings engraved on the brass collar and the part number the same as the one removed, No picture showing the rings and part No. Was in a VW bag listed as Skoda i think. Will dig out an image bag in the garage.
Replacement Sensor
One removed
Hopefully not been sold a dummy!!
Post by Shoppinit » Sun Feb 02, 2025 12:24 pm
Hmm.
About this seller
Spare Parts-Cheap 2017
99.6% positive Feedback•75K items sold
Joined Oct 2017
Usually responds within 24 hours
Registered as a private seller
Thereby, consumer rights stemming from EU consumer protection law do not apply. eBay buyer protection still applies to most purchases.
With 75000 sales?
Doesn't mean it's not a legit sensor, but I wouldn't trust a seller that claimed to be private to avoid responsibilities.
I think I would have got this:
https://www.autodoc.co.uk/beru/7515442
Or from a VAG dealer directly. They're not particularly expensive parts.
srichards
Post by srichards » Sun Feb 02, 2025 12:25 pm
Febi one with the sealing rings
https://www.autodoc.co.uk/febi-bilstein/1888486
It lists the RS6 4.2 engine as a suitable application.
Post by Shoppinit » Sun Feb 02, 2025 12:27 pm
Yeah, Febi is OK. Beru is the king though.
cover99
Post by cover99 » Sun Feb 02, 2025 12:30 pm
Thanks both will order one from Autodoc or directly from Audi as a spare.
I have ran a further Auto scan after running the car for a good 15 minutes. I will do a separate scan on 01 engine as you suggest later on. VCDS Log taken after a 15 minute run.
Sunday,02,February,2025,01:08:11:20920
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WUAZZZ4B54N901020 License Plate: E13SMD
Mileage: 42066 Repair Order: After Restart
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0002
Coding: 0010752
Shop #: WSC 66565 257 00032
VCID: 6B8418848F90EBD29A9-5160
VINID: 9E546AAAA11214478900100200826CDC3A
No fault code found.
Readiness: 0010 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 02195
VCID: 6C861B988F9EECEA933-516C
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 02195
VCID: 639470A46240A392229-5160
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00001
Shop #: WSC 00189
VCID: 6A8A1D80855AF2DAE1F-258E
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 AA
Component: Airbag 8.4EP 1002
Coding: 0000606
Shop #: WSC 02195 785 00200
VCID: 6FBC0C94BB8817F2B61-5160
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 B
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 01484
Shop #: WSC 37301
VCID: 270C24B456F80FB23E1-5160
WUAZZZ4B54N901020 AUZ7Z0C2485385
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 06859
Shop #: WSC 02195
VCID: 3436C3F8971E742A8B3-4F12
1 Fault Found:
01134 - Alarm Horn (H12)
77-00 - Internal Supply Voltage
Address 37: Navigation Labels: 4B0-035-192-RNSD-37.lbl
Part No: 4B0 035 192 K
Component: RNS 4.2 H06 BNO 0140
VCID: 25102EBC2CC41DA20CD-4B02
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02195
VCID: 261229B051C216BA057-514A
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 00182
VCID: 04565338873E04AA7B3-4B3A
Address 56: Radio Labels: 4B0-035-192-RNSD-56.lbl
Component: Radio BNO 0001
Coding: 00017
Shop #: WSC 00189
Address 57: TV Tuner Labels: 4D0-919-146.clb
Part No: 4D0 919 146 B
Component: TV Tuner H10~1206
Coding: 0000010
Shop #: WSC 00182 210 83141
VCID: 280E27885ED600CA37B-5160
Address 65: Tire Pressure Labels: 4D0-907-273.lbl
Part No: 4D0 907 273 C
Component: Reifendruckueberw. D310
Coding: 22350
Shop #: WSC 02195
VCID: 270C24B456C80FB23E1-5160
Address 76: Park Assist Labels: 8E0-919-283-8E2.lbl
Part No: 8E0 919 283
Component: Parkingsyst. A6 RDW D09
Coding: 01156
Shop #: WSC 02195
VCID: 6D80169CB4B4E5E284D-5160
End----------(Elapsed Time: 04:19, VBatt start/end: 12.6V/12.5V)-----------
Post by Shoppinit » Sun Feb 02, 2025 12:31 pm
Nice and clean. :thumbs:
Go to ECU and "measuring blocks" and see what you've got in group 032. That's your trim.
steve2003rs6
Post by steve2003rs6 » Mon Feb 03, 2025 10:54 am
Ben.
Autodoc says the Beru sensor is not compatible for our vehicles.
The Febi sensor shows compatibility
HPsauce
Post by HPsauce » Mon Feb 03, 2025 11:51 am
The infamous CTS! That would certainly make the engine run oddly or be difficult to start.
I've replaced quite a few over the years and several have been dodgy even though they appeared 100% genuine. In the end I went to a VW main dealer parts department to get genuine.
If you do that they sell the sensor, ring and clip as 3 separate items!
srichards
Post by srichards » Mon Feb 03, 2025 12:03 pm
The Febi one I think has all the bits together.
Post by Shoppinit » Mon Feb 03, 2025 12:07 pm
Ben.
VAG part number 059919501A. Autodoc shows that the Beru part is equivalent.
steve2003rs6
Post by steve2003rs6 » Mon Feb 03, 2025 12:19 pm
I just used your above link ?
Post by Shoppinit » Mon Feb 03, 2025 12:24 pm
cover99
Post by cover99 » Mon Feb 03, 2025 7:26 pm
steve2003rs6 wrote:
Sat Feb 01, 2025 4:34 pm
If that’s the first scan I would be very happy with that.
As Ben has said clear the faults. Run the car for a few days and then rescan to see what comes back.
Wouldn’t be too concerned about the radio or the central locking at the moment. I have both of these error codes.
I would be looking to see if the G62 code comes back.
Especially if you have just replaced it.
I replaced my G62 sensor recently. Like you I had rough running. Sometimes problems starting the car with that error.
Thankfully after installing a new sensor my problem was cured.
Like you I cannot connect with can. I have to select the car from the list.
Cheers sounds similar to my issue and good to hear the connection by CAN and having to connect from the list is not any problem.
Users browsing this forum: Google [Bot], Majestic-12 [Bot], TOPMAN and 46 guests
