Ticking noise...
skinflintcustoms
Ticking noise...
Post by skinflintcustoms » Sat Nov 16, 2024 8:02 pm
Has anyone had this problem? on a cold start the engine is making a ticking noise, once warmed up it goes away, new plugs new coil packs and full service?
Its not rocket science do it yourself.
TOPMAN
Re: Ticking noise...
Post by TOPMAN » Sat Nov 16, 2024 11:20 pm
If the ticking noise lasts just a second or two, when the engine is cold, then I wouldn't worry to much. It's normally a bit of chain chatter on the tensioner pads before the oil pressure has built up. My engine had new chains, oil pump, genuine tensioners and still taps for a second or two on cold start. It goes once the oil pressure is there.
I'm interested in others experiences and opinions though :audibash:
Post by Shoppinit » Sat Nov 16, 2024 11:24 pm
Or just a noisy tappet. If mine hasn’t run for a while and they are quite noisy for a bit. Sometimes takes a few minutes to settle down completely.
Mɐʇʇ
Post by Mɐʇʇ » Sun Nov 17, 2024 2:18 pm
^ this. Basically the lifters bleed down over time and get a little stuck sometimes until you get some heat in them to loosen up.
Best thing to do is go for a drive, you want oil temps. And run the motor a little more regularly if you can.
Felix2566
Post by Felix2566 » Mon Nov 18, 2024 1:52 pm
Mine was the same after evening stood for months, had a lot of noise from the lifters untill they calmed down. Now after using it more it's just a bit clattery for a second or 2 and then all quiet. As the others have said, a bit more use and it should go away. Possibly an oil change if it hasnt had one recently.
steve2003rs6
Post by steve2003rs6 » Thu Nov 21, 2024 6:23 pm
My hydraulic tappets can be a bit noisy on startup.
Very quickly disappears once the oil pressure builds up.
Users browsing this forum: ChrisA, Majestic-12 [Bot] and 103 guests
