This TapaTalk for my beta version of iOS is not working correctly. Sends weird lines of emoji-code if I try to add photos and text together. Easier to upload the photos and then edit the post in a regular browser later. I have replaced the pipes that I felt were a little suspect, replaced the water pump, pressure pipe O rings and the IAT. It's slowly coming back together
I pulled the manifold because my SJP broke (in the way they always do!) while I was there I tested the water pump and that was dead alsoFelix2566 wrote:Did you have it off for a fault, or just preventative/make it look pretty?
I can think of stronger words, but faff will do
A brake booster valve in the traditional sense is a one-way vacuum pipe valve connected to the booster. The role of the SJP is different in the way that it uses the venturi effect to improve vacuum when you first take your foot off of the accelerator pedal.steve2003rs6 wrote: ↑Thu Oct 03, 2024 1:53 pmsuction jet pump = brake booster valve ?
Are they the same thing.
Users browsing this forum: No registered users and 256 guests
