SJP continued
TOPMAN
SJP continued
Post by TOPMAN » Tue Aug 20, 2024 8:59 pm
For those of you who have stripped one of these manifolds/intake and put them back together I salute you :bowdown: what a pain in the rear-end that was :lol:
Re: SJP continued
Post by Shoppinit » Wed Aug 21, 2024 12:52 am
Pretty
TOPMAN
Re: SJP continued
Post by TOPMAN » Wed Aug 21, 2024 5:44 pm
Pretty
This TapaTalk for my beta version of iOS is not working correctly. Sends weird lines of emoji-code if I try to add photos and text together. Easier to upload the photos and then edit the post in a regular browser later. I have replaced the pipes that I felt were a little suspect, replaced the water pump, pressure pipe O rings and the IAT. It's slowly coming back together :audibash:
Notice the metal pipe from the SJP to the brake-booster. All other versions I have seen are made from a hard plastic with a heat-shield. My engine is a BRV from a PLUS+ model, so I am wondering if this was a modification for the later cars or just for the BRV?
steve2003rs6
Re: SJP continued
Post by steve2003rs6 » Wed Aug 21, 2024 6:28 pm
Hats off to you sir. That looks amazing. It may have been a pain in the rear to do.
But you can now stand back and marvel at the finished result.
Felix2566
Re: SJP continued
Post by Felix2566 » Thu Aug 22, 2024 11:23 am
Did you have it off for a fault, or just preventative/make it look pretty?
TOPMAN
Re: SJP continued
Post by TOPMAN » Thu Aug 22, 2024 11:30 am
Felix2566 wrote:Did you have it off for a fault, or just preventative/make it look pretty?
I pulled the manifold because my SJP broke (in the way they always do!) while I was there I tested the water pump and that was dead also ImageImage
TOPMAN
Re: SJP continued
Post by TOPMAN » Thu Oct 03, 2024 1:31 pm
Small update: Engine now runs, just a few little things to do before MOT. I like how it looks before all those silly cables and pipes are connected!
steve2003rs6
Re: SJP continued
Post by steve2003rs6 » Thu Oct 03, 2024 1:38 pm
Really nice work Craig.
So that’s where the brake booster valve and auxiliary water pump fits.
Had unit 20 replace my brake booster valve a while ago.
I have a new auxiliary water pump for when I need it.
Forgive my ignorance but what does SJP stand for.
Re: SJP continued
Post by Shoppinit » Thu Oct 03, 2024 1:46 pm
What a massive faff for a small plastic part.
TOPMAN
Re: SJP continued
Post by TOPMAN » Thu Oct 03, 2024 1:48 pm
SJP = SuctionJet Pump :biggrin3:
TOPMAN
Re: SJP continued
Post by TOPMAN » Thu Oct 03, 2024 1:49 pm
I can think of stronger words, but faff will do :audibash:
steve2003rs6
Re: SJP continued
Post by steve2003rs6 » Thu Oct 03, 2024 1:53 pm
suction jet pump = brake booster valve ?
Are they the same thing.
TOPMAN
Re: SJP continued
Post by TOPMAN » Thu Oct 03, 2024 2:06 pm
Lots of new bits while doing this job
New upper and lower MAF seals, new seals in pressure regulator, new throttle body O ring, new inlet gaskets (of course).
New IAT sensor, new Pierburg water pump, new updated SJP, new spark plugs, new red-top coils and adapters, new silicone vacuum hoses (some not all), new billet type PCV valve, new OEM air filters.
The list will continue I am sure :audibash:
TOPMAN
Re: SJP continued
Post by TOPMAN » Thu Oct 03, 2024 2:10 pm
A brake booster valve in the traditional sense is a one-way vacuum pipe valve connected to the booster. The role of the SJP is different in the way that it uses the venturi effect to improve vacuum when you first take your foot off of the accelerator pedal.
Marcin
Re: SJP continued
Post by Marcin » Thu Oct 03, 2024 2:47 pm
I had the same problem with my one right after purchase. At least it was still covered by the warranty.
Is:
2003 RS6 | 2013 A6 BiTDI quattro | 2016 Corsa ;) | Suzuki GSX-R 1000 K6
was:
2004 A6 3.0TDI quattro | 2000 A6 1.8T quattro | 1997 A6 1.8 | 1998 Opel Vectra 1.6 | 1985 VW Santana |
Users browsing this forum: Google [Bot] and 49 guests
