VCDS problem.
Re: VCDS problem.
Will give that a try Ben.
I have informed Ross tech that it looks like version 24.7 has a problem.
Last edited by steve2003rs6 on Sat Aug 17, 2024 10:49 am, edited 2 times in total.
Re: VCDS problem.
Hi Ben.
There is a known problem. And it is the exact problem I am experiencing.
Ross tech are advising me to download the beta version 24.8 and to make 1 or 2 setting adjustments in beta.
Have asked them for an idiots guide as I am not that good with computers.
Will report back when I get a response.
Last edited by steve2003rs6 on Sat Aug 17, 2024 10:50 am, edited 3 times in total.
Re: VCDS problem.
I have downloaded beta 24.8 version.
Just the other config bits to sort out.
Ross tech have asked for an update to see if it resolves the immediate problem.
- stuartbarriskell
Re: VCDS problem.
I'm on W10 and I... DL 24.7 today no bother
Sent from my SM-S918B using Tapatalk
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Re: VCDS problem.
I guess I am just lucky Stuart.
Shoppinit had a similar problem
It’s been a real pain.
I had no problems until I updated to 24.7
And it’s a new genuine unlimited vins Ross tech cable.
- stuartbarriskell
Re: VCDS problem.
I jumped on this morning to look for something in my car/bike folder and just clicked on the VCDS Icon, updated no bother Steve.. haven't used it in anger tho, cars running fine just now..touch wood !
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Re: VCDS problem.
Ross tech informed me they rectified a similar software fault on the beta version. That was rectified a week ago.
Hence why they have advised me to use beta.
Pleased your car is running ok.
When everything is working well, There is no
doubt about it. These cars are epic.
Re: VCDS problem.
Ok so currently scanning the car using BETA
That went well
Clear faults
Then
Function not supported by the gateway.
Holy crap. Doing my head in
That went well
Clear faults
Then
Re: VCDS problem.
At what point precisely is it giving that error message?
Re: VCDS problem.
As soon as you press the clear faults
Re: VCDS problem.
Did it revert to "Auto-detect (CAN only)" in the drop down after the scan?
Why don't you ask Rosstech for an older version. I'm using 21.9.0 and it appears to be fine (albeit you have to manually select the chassis).
For a long time I used Release 15.7.3 because I am always averse to updating unless I absolutely have to. Don't know if that version works on Win10 though.
There is nothing in the later versions (>15) that is useful for the RS6, but I needed to update it for more modern cars.
Re: VCDS problem.
Cannot change CAN timeout. Not an option.
Re: VCDS problem.
Tick "Bypass CAN init" to see what happens.
Re: VCDS problem.
Cheers Ben.
Re: VCDS problem.
Will give that a try in the morning. Had dfs here over a crap suite they sold us. Taking it to ombudsman. Loads of forms to fill out and info to gather.
Then taking mrs shopping. Run out of time today.
Have emailed Ross tech to see if I can download an older version.
Waiting to hear.
Waiting to hear.
