Has anyone actually lowered a B9.5 RS4?!
2.9 V6 24v TFSI - 444 bhp
JAY8P
Post by JAY8P » Wed May 29, 2024 10:09 pm
Hey guys,
I recently installed 034 Motorsport lowering springs to my B9.5 RS4 but really aren’t happy with the results. The front has come down nicely (around 15mm) but the rear looks unchanged. I’ve been in dialogue with 034 regarding this but it looks as if I’m going to need to return them and try a different brand. Question is, lowering a B9/9.5 seems to be rare online so I’m looking for photos of other members cars. Please post up and specify what mm and brand fitted. Here’s photos of mine in question
Jools
Re: Has anyone actually lowered a B9.5 RS4?!
Post by Jools » Thu May 30, 2024 6:05 pm
It doesn't look like the rear end has settled yet, have you tried loading up the boot and then unloading.
How did the new rear spring length compare to the old ones, its almost as if they got the front and rear springs mixed up when they were fitting them?
Does your car have DRC?
Does the car need to have the ride height recalibrated after the lowering, as if not, if it has auto leveling it may be trying to compensate for it reading low as the springs are letting it sit lower than stock and jacking it up to bring it back to where it thinks it should be.
Fabiogray
Post by Fabiogray » Sat Jun 01, 2024 9:15 pm
The rear of the car must always be slightly higher than the front, that looks perfect, if you bring the rear lower it will kill the handling seen it many times
Leask
Post by Leask » Sun Jun 09, 2024 4:30 pm
mine has the the sports suspension from factory (not sure if they all did?) i think mine sits pretty low compared to some from factory , dont know lol
2019 Audi RS4
rjwojcik
Post by rjwojcik » Sun Jun 09, 2024 7:36 pm
Didn't know sports suspension was an option, any idea what the Audi code is?
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
elchet
Post by elchet » Mon Jun 10, 2024 12:10 pm
It wasn't. RS Sports Suspension was standard, and the option was RS Sports Suspension Plus with DRC (code 2MC)
2018 B9 RS4 Daytona Grey
Jools
Post by Jools » Mon Jun 10, 2024 6:11 pm
Just some extra info, I just looked at my manual on steering and suspension.
My car has DRC looking at my build Sticker this is far RHS column second row down (2MC).
Cross referrencing this to the page from the manual my front ride height should be (bottom row in the table) 367mm +/- 10mm and rear 371mm +/- 10mm.
From this you should be able to do a comparison at least on how much the front has actually dropped by with your new springs and compare the rear with a non lowered car.
I'm guessing the 2MS in the running gear column is the non-DRC build, maybe someone else in the forum can confirm.
rjwojcik
Post by rjwojcik » Tue Jun 11, 2024 7:21 am
Thanks, I thought I'd missed something
JAY8P
Post by JAY8P » Sat Jun 15, 2024 8:44 pm
Update:
So some interesting developments here. After back and forth with a supplier (who shall remain anonymous) it turns out they advised me and supplied me with the wrong springs. I’m also now learning that RS5/S4 springs are different to RS4 Avant springs, quite substantially! So today, I stripped the suspension down for a second time and fitted some H&R springs. Now the car sits perfect and I’m really happy it’s how I want it.
I am starting to believe that I’m the first person to fit lowering springs to their B9.5 RS4, there’s no info/images anywhere!
JAY8P
Post by JAY8P » Sat Jun 15, 2024 8:47 pm
Jools
Post by Jools » Sun Jun 16, 2024 10:58 am
That looks better. I can see the RS5 / S5 springs would be different as the Coupe body is lighter than an Avant body.
Let us know if you suffer from any rubbing? It looks like you are running spacers as well.
Khurem
Post by Khurem » Mon Jun 17, 2024 11:04 pm
How are you finding the ride? Is it a lot harsher than stock?
Also, as above any rubbing?
Rs4 b9.5
Leask
Post by Leask » Sat Jun 22, 2024 4:12 pm
size wheels 19's or 20's?
2019 Audi RS4
Jools
Post by Jools » Sun Jun 23, 2024 11:57 pm
20" the size is on the tyre wall if you zoom in
Khurem
Post by Khurem » Wed Aug 13, 2025 5:21 pm
I’ve lowered my car using H&R springs and am experiencing front wheel rub when turning. I’m running 275/30/20 tyres.
What would be the easiest short-term fix, and what would be the proper long-term fix to completely eliminate wheel rub? Would adding negative camber by replacing the upper control arms be an effective solution? Or is there a way to adjust the oem control arms?
Rs4 b9.5
