Which Dash Cam ?
4.2 V8 32v FSI - 444 bhp
stuartbarriskell
Which Dash Cam ?
Post by stuartbarriskell » Wed Apr 03, 2024 12:39 am
Must be an age thing, I'm thinking more often about getting a dash cam the last wee while, not only because of the <beep> roads and a potential claim but more for idiot drivers and to help keep me in the clear in the event of a smash.
Anyone got one fitted, don't mind spending a bit, and can fit myself. Any recommendations would be helpful.
Sent from my SM-S918B using Tapatalk
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Rs4nutter
Re: Which Dash Cam ?
Post by Rs4nutter » Wed Apr 03, 2024 7:09 am
@stuartbarriskell I've got a Nextbase fitted, 322 model, with a rear facing camera also fitted in case of a rear end shunt!! Bought a hard wire kit so its not in fag lighter, down side, the fuse is in boot on right hand side so its not permently on.
Hope that helps, had several Nextbase fitted to various car. Would recommend a good memory card, cheap ones dont last in camera!!
stuartbarriskell
Post by stuartbarriskell » Wed Apr 03, 2024 7:13 am
Yea, that helps. I started to wonder about power and run a lead along the footwell area and up into the door frame. Is it a piggyback fuse connector? Why is it not on all the time? Do you mean when the car is switched off.
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Rs4nutter
Post by Rs4nutter » Wed Apr 03, 2024 11:21 pm
Yeah, the Nextbase hardwire kit uses a piggyback fuse connector for power. Think the fag lighter is constant live, not 100% sure, but I have set camera to self turn off after a certain amount of time, as I used to work away and always forgot to turn it off, queue flat battery!!🤦🏻‍♂️
Hope this helps,
p.s. hardwire kit cables are long enough to run length of car
stuartbarriskell
Post by stuartbarriskell » Wed Apr 03, 2024 11:25 pm
Excellent I'll wait till the better weather comes in and get stuck into it..
The fag lighter power plug is horrible, so did you take a feed out the back of the wiring to it or did you run the line rear to front
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
CusterDome
Post by CusterDome » Thu Apr 04, 2024 10:01 am
I've also been thinking about this, for pretty much the same reasons as Stu.
The rear view mirror has power, I'm assuming it's not possible to connect to this and avoid having to route cables?
Mav8
Post by Mav8 » Thu Apr 04, 2024 10:52 am
Another vote for the Nextbase, I have it my RS👍
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
Rs4nutter
Post by Rs4nutter » Thu Apr 04, 2024 9:54 pm
Used fuse in boot and run power cable to front under plastic panels at bottom of doors and then up A pillar and across top of windscreen
RS4_Kid
Post by RS4_Kid » Thu Apr 04, 2024 10:46 pm
My dashcam comes with parking mode so needs permanent and switched live feeds. It was easy enough to run the power cable down the a pillar into drivers side fuse box using piggy back fuses.
stuartbarriskell
Post by stuartbarriskell » Fri Apr 05, 2024 8:12 pm
CusterDome wrote:I've also been thinking about this, for pretty much the same reasons as Stu.
Funnily enough, I came across this. I've to send the guy pics of the mirror mount left and right. Seems they do them for our particular models...
Looks pretty easy to fit, no pissing about trying to get a feed from the fuse box and then a cable run.
https://a.aliexpress.com/_EzNtomV
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
stuartbarriskell
Post by stuartbarriskell » Fri Apr 05, 2024 8:16 pm
Rs4nutter wrote:Used fuse in boot and run power cable to front under plastic panels at bottom of doors and then up A pillar and across top of windscreen
Was it easy enough to route the cables ?
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Users browsing this forum: Google Adsense [Bot] and 26 guests
