Xenon headlight bulb issue
4.2 V8 32v FSI - 444 bhp
hindsight
Post by hindsight » Mon Nov 18, 2019 12:11 am
Hi all
Had a long roundtrip (450 miles) in the rs4 yesterday unfortunately as I was starting to head home I got a warning on the dash saying "right dipped headlight/main beam headlight" and pic of a bulb with cross through it. Sure enough the driver's headlight was off. Bit annoying being so far from home but I got home taking it very steady.
Anyway my question is whether it is a simple bulb failure or something else as when restarting the car today the bulb came on (looked bit dim) then after 90 secs it switched off and the dash warning came on again. It did this on three occasions today so the bulb hasn't totally failed.
Second question I got the car about 6 months ago as audi approved from sytner audi Nottingham and it has a 1yr Audi warranty. It also had mot failure cover but I imagine they could argue it is wear and tear, but does anyone know if bulb replacement is covered?
Any advice before I call my local audi dealer (slough or amersham) much appreciated.
wideboy
Re: Xenon headlight bulb issue
Post by wideboy » Wed Nov 27, 2019 10:54 am
Mine died last year (2015 plate).
Replaced bulb but no joy, it was the headlight ballast that had gone. (replace bulbs in pairs).
Unlikely to be replaced by the dealer FOC, but always worth asking.
It's an easy but somewhat faffy DIY, to change both bulb and ballast you need to remove the headlights. Ballast it simply on the bottom of the headlight. I couldn't source an audi ballast, you may need a new headlight if you go through the dealer? But I found a suitable replacement from an eBay seller for around £40 new.
Rusty Racer
Post by Rusty Racer » Fri Dec 20, 2019 10:00 am
Same issue on mine, dealer warranty covered ballast.
2018 RS4 B9 Carbon Edition
2014 RS4 B8
CRSRS
Post by CRSRS » Mon Dec 14, 2020 1:35 pm
Morning all, I believe I have the same issue with an error message “right dipped headlight”. Does anyone have a link to buying the ballast unit or the part number. Also how easy is it to change it? All help is greatly appreciated.
2007 RS4 Avus avant - now gone
2013 RS3 black - bye bye
2013 B8 RS4 - Sepang, Ceramics, Buckets, Carbon pack, Sports pack, ACC, B&O, privacy. - now gone
2017 C7 PE - Panther, Ceramics, Carbon pack, BO upgrade.
wideboy
Post by wideboy » Wed Dec 23, 2020 7:38 pm
Its dead easy, about 4 bolts and 3 screws.
Here's the ballast i used, fitted 2years ago and still good now:
https://www.google.com/url?sa=t&source= ... ewXtJipjk4
My 2nd side died yesterday just after MOT. Eugh. My car is a 2014 and garaged and thats both oem units failed now. Both units had signs of water ingress.
Audi were going to do it on my warranty but i declined as excess is £250. Told them to book it in for a retest and that I'd collect the car and do it myself.
Called back a few min later with a good will offer! Still £130 but saved me the hassle of collecting car twice.
List price for parts only at Audi was £275!!!
535dboy
Post by 535dboy » Thu Dec 24, 2020 5:53 am
I was going to say, if the ballast then surely that is warranty but probably not if it is the bulb.
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Geoff A
Post by Geoff A » Thu Dec 24, 2020 10:45 am
Xenons are fully covered under my Audi extended warranty. Just had one done at Stratford Audi, and it cost just the £100 excess, but the retail value was around £1100 for a bulb and controller.
Sadly, it’s still trouble as it comes on for about 45 seconds then goes out, but they put a 2yr warranty on the genuine replacement parts., and it’s going back in next week.
CRSRS
Post by CRSRS » Tue Jan 05, 2021 1:40 am
Great thanks, have bought a bulb and will see if it works if not will change the ballast. Appreciate the intel. 😀
[/quote]
CRSRS
Post by CRSRS » Mon Jan 11, 2021 12:37 am
Thanks all the help. Changed bulb, still didn’t work so changed the ballast and now working. Like other say it is a bit of a hassle but only managed to drop one screw down the back. Just need to work out if alignment is still ok now? 😀
johnnydog
Post by johnnydog » Thu Feb 29, 2024 9:09 pm
When my offside headlight failed last year, I swapped the bulb from one side to the other to check if the fault was the bulb or ballast. (If the fault changes side then the bulb is faulty; if the fault stays at the same side, then its likely to be the ballast). My fault stayed on the offside and the bulb worked in the other headlight, so..... I bought a new ballast off Ebay for £50 (boxed as a VW part although I suspect it wasnt, even though it was a Mitsubishi ballast like the original), and it now works fine and it passed its MOT recently - I guess if the alignment was slightly out, they usually would adjust it anyway. I have the Audi extended warranty too, but with the £250 excess, decided it was worth taking a punt on doing it myself.
Frankt3323
Post by Frankt3323 » Fri Mar 15, 2024 12:54 pm
I wish I had read this before. Had the same issue recently which ended up with a lot of Specialist dealer diagnostics to define it was the controller and several hundred £'s later we are back on the road legally. Asked if it was a standard part (ie not specific to RS models) but told no.
Seems like a common fault on Audi's that are aging.
Black on Black on Black B8 RS4
:blackrs4:
johnnydog
Post by johnnydog » Sat Mar 16, 2024 11:42 am
I would argue your 'specialist is not entirely correct at all. The original 'Audi' ballasts are made by Mitsubishi, and the part no. is common to other Audi's with Xenons across the range, not just RS models. As long as the part no. and suffix is the same, then it is suitable.
Users browsing this forum: No registered users and 27 guests
