mines at 77k - so relatively low, but just slightly higher mileage than yours .. and this is the condition of it:
Want to keep OEM, as opposed to installing a CAI for example - but replacement Aux. Rad from Audi is .. £254.50+vat !
Can you get parts from TPS?
Looks like its a stretch bolt.r8wut wrote: ↑Sun Nov 05, 2023 7:01 pmSUPERB!! guess I owe you a cold one![]()
Thank-you - if it's ok with you.. i'll update this thread with my progress too..
Access to and removing the sump (which is quite rusty) is a bit of a ball ache..
Firstly, as you have to remove the Coolant supply hardline pipe [079121481R] from the water pump to the engine block.. and I managed to strip one of the torx bolts in the process![]()
Don't worry. Managed to partially drill out and remove the bolt .. thankfully without damaging the threads on the block..
-Would you know the torque valves for these Torx Bolts please?
Used to fairly frequently. Moved address , so now have to setup an Account with a different TPS Branch
I can vouch for Reyland discs. I opted for the uprated 380mm front 360mm rear floating options which are a massive upgrade over standard. Coupled with DS2500 pads front and rear, they give immense bite and stopping power, something I always felt the OEM setup lacked.r8wut wrote: ↑Mon Nov 06, 2023 12:34 amlucky your Aux Rad is still ok..
Well.. I'm working through a Full overhaul / replacement of mostly everything.. will briefly try and break it down:
1. Completed Installation of KW V1's front and rear to replace leaky DRC setup.
2. new Front & Rear Discs and Pads all round - yet to decide.. Reylands ?
3. Front + Rear Anti Roll Bar Bushes
4. Need to purchase HEL Braided Hoses Front & Rear
5. Replacement of ALL fluids: Engine oil, Gearbox and Diff oils, coolant, power steering and brake fluids
6. Sump replacement, due to corrosion. Would have done anyway, as perfect opportunity to inspect Oil Pickup pipe gauze for any blockages
7. Full Carbon Clean inc. PCV valve replacement, vacuum valves, oil filter housing seals
8. New Rocker / Valve cover seals x2
9. Deliberating on 8x new OE / Hitachi Fuel Injectors (expensive!)
10. Oil Filter, Fuel Filter etc.
11. New Bonnet latch
12. New Fuel Flap cap release actuator latch
Suffice to say.
Looks like I might need to re-mortgage the house.
Users browsing this forum: Google Adsense [Bot] and 135 guests
