Replacement Headunit From Pluscenter
Hi All,
I'm looking to replace my head unit to something a little more modern. Has anyone installed this unit from PlusCenter in the UK? It looks pretty good and reasonably priced. Thoughts? recomendations?
https://pluscenter.co.uk/products/audi- ... 2219269253
Thanks in advance,
Richard
Thanks in advance,
Richard
Re: Replacement Headunit From Pluscenter
That does look good. Never been a fan of the surrounds you normally need with a non OEM headunit. This one doesn't seem to have one so should fill the space nicely.
I doubt it'll fully work with driver display though. Maybe you should get one & write a full report.
Just saw this on YouTube...Sneakybutcher wrote: ↑Thu Jul 06, 2023 12:46 pmHi All,
Thanks in advance,
Richard
https://youtu.be/CejgPCoUsK4
Not sure, but this build might have one fitted??
Did you get one of these units?Sneakybutcher wrote: ↑Thu Jul 06, 2023 12:46 pmHi All,
Thanks in advance,
Richard
I did, it works a treat. Fitment was easy with the supplied wiring harness. No cutting or joining of cables just plug and play. It has a sim card for internet. Can run all android apps, has Apple Carplay, Android car, waze, maps, everything plus more than you need. I can connect it to my OBDII port and have extra guages and information on it. If I want to revert to stock its a 5 minute job. The fitment is good but does nor secure with clips or anything just a press fit but very tight.
Sounds like you're pleased with it. Could you shsre some pics please?Sneakybutcher wrote: ↑Mon Jul 31, 2023 4:37 pmI did, it works a treat. Fitment was easy with the supplied wiring harness. No cutting or joining of cables just plug and play. It has a sim card for internet. Can run all android apps, has Apple Carplay, Android car, waze, maps, everything plus more than you need. I can connect it to my OBDII port and have extra guages and information on it. If I want to revert to stock its a 5 minute job. The fitment is good but does nor secure with clips or anything just a press fit but very tight.
Looks pretty good. I'm sure some would be put off as the brand is unknown.
Did you have to buy a DAB aerial for it?
Looks very good.
Users browsing this forum: dan32v and 104 guests
