Alloy radiator
Re: Alloy radiator
To everybody interested proalloy now have the ability to make alloy radiators for the c5 rs6 at this stage it is only available a full coolant rad which means you will loose the integrated gearbox cooler that’s with in the standard rad.
If you would like a price then please email sales@proalloy.co.uk
They will be more than happy to process your order.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Alloy radiator
Good work Wes.
Re: Alloy radiator
Thanks Chris it’s been a long process but I’m sure it will be worth it for the community
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Alloy radiator
Yes, thank you. This is great for the community. Cheers
Re: Alloy radiator
Yeah I’m Nobby from there too. Used to have a Scott’s Green 20vt - owned for 10 years. Ended up having kids, breaking my foot, then hurting my knee pretty bad whilst the MOT ran out. Then bought the RS6. Took the coupe apart and sold it.ChrisA wrote: ↑Wed Mar 08, 2023 8:51 amLol, small world. Did you used to post under Nobby, I certainly remember the name? I posted as OO7, I’m still able to log in and to this day I still think it was the best forum I’ve ever used. I absolutely adored my Coupe, I brought it in my early 20s stock and kept it for around 8 years using it as a daily modding it to 325bhp. I eventually sold it to fund setting up my own electrical installation company.
My old girl (no pictures sadly)
https://www.fiatcoupeclub.org/forum/ubb ... Post464710
Daytona RS6 Avant
Re: Alloy radiator
So pro alloy have been inundated with emails from people Al around the world about this radiator.
They are just putting together final figures but expect it to be around £1k mark for buying.
They are also wanting somebody with an C5 S6 rad to help for development on that car to.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Alloy radiator
What would be the effect of installing the pro alloy rad without the integrated gearbox cooler.
Please forgive my ignorance.
I would like to install a new rad.
But don’t know what the compromise is.
Eg do you have to install another cooler for the gearbox
Re: Alloy radiator
From memory, it helps bring the transmission up to temperature as well as cooling once it gets hot.
Re: Alloy radiator
You don’t have to install another cooler as the car does run 2 gearbox oil coolers from factory.steve2003rs6 wrote: ↑Tue Apr 18, 2023 4:42 pmWhat would be the effect of installing the pro alloy rad without the integrated gearbox cooler.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Alloy radiator
Hi guys. I feel like a proper dumbo.
Apparently my radiator does not have the built in gearbox oil cooler.
Just bought new under rad oil cooler
New front discs
New small 280 mm coolant fan
About to buy large 360mm coolant fan
So funds are getting low at the moment.
When this is all sorted I will then look again at the radiator.
New front discs
Re: Alloy radiator
This alloy rad will fit your car perfectly then.steve2003rs6 wrote: ↑Fri Apr 21, 2023 8:41 pmHi guys. I feel like a proper dumbo.
New front discs
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Alloy radiator
The finalised price these will be sold at - £988.12 + VAT (without intergrated internal oil cooler Spec'd with PRO 65mm Motorsport core)
If you are wanting to order then please contact pro alloy. www.proalloy.co.uk
01440 710266
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Re: Alloy radiator
To all the people that want the radiator with the interstates gearbox oil cooler I have news for you.
I have now swapped my rads over and send the original to pro alloy so they can now work on/out how to integrate the gearbox oil cooler. I’m sure it won’t be to long until they will be able to sell them
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
- anditsoundslikebells
Re: Alloy radiator
I'm in the market for a new radiator and remembered this post.
Did the Pro Alloy integrated radiator appear?
RS6 C5 Avant 2002 Daytona Grey
TTH 620 - Wagner IC - OC.T 200cell&downpipes - DW400 pump - 034 TCU chip - FIS - B16 PSS9 - 034 control arms - H&R ARB - OZ Superturismo
Re: Alloy radiator
They can do the integrated oil cooler yes.
C5 RS6 Avant
800+ BHP loading
1100+ ft lb loading
800+ BHP loading
1100+ ft lb loading
Users browsing this forum: 111marc111, Bing [Bot], Bowers155 and 100 guests
