intermittent ABS fault v39 00301
djbilbao
Post by djbilbao » Wed Mar 22, 2023 10:16 pm
00301 - ABS Return Flow Pump (V39)
35-00
hello to all, I have this fault which appeared after a long stoppage, ABS delivery pump v39 00301, I checked the earth ok, put some contact cleaner in the main connector ok but the fault persists, I have dismantle the cover of the ABS pump to clean the brushes of the pump but I don't know how to remove the rotor from the ABS block? an idea ? Thanks in advanceImageImage
Envoyé de mon M2012K11AG en utilisant Tapatalk
Re: intermittent ABS fault v39 00301
Post by Shoppinit » Thu Mar 23, 2023 9:17 am
viewtopic.php?f=2&t=133626&p=946150
viewtopic.php?f=2&t=133951&p=930536
But my fear would be that the controller is faulty. This is the cause of 90% of ABS faults.
djbilbao
Post by djbilbao » Fri Mar 24, 2023 8:48 pm
what is curious is that it is not all the time I clean the coals, I will demonstrate the computer part with the 2 blades possible bad contact
Gregstv
Post by Gregstv » Sat Mar 25, 2023 7:31 am
I got a second hand ABS module from Heil Williams. Fixed my intermittent pump failure. Been good now for over 12 months.
Users browsing this forum: d-9, Google [Bot], simonmcc and 40 guests
