Assuming that brass dial is your adjuster, how many steps does it have, do you have the data chart for the adjustments?
What are you doing with your existing DRC system... what state is it in??
How many miles have you got, and I could be interested if the shocks are in decent conditionImola_Sid wrote:9 settings I believe. Will check the paperwork and post up if i find any relevant info.
The original DRC was perfect until the leak. When it's taken apart i'll get the mechanic to check where the leak was from (hopefully not from the shocks).. If the shocks are ok, will sell as parts to go towards the recent work (starter motor, suspension, brakes etc).. it's been an expensive month!
