Pressure relief valve : how does it work?
Classik
Post by Classik » Sat Nov 19, 2022 12:33 am
Parts #24, front of the engine
Hi,
Could someone explain how are those supposed to work?
Thanks!
Loba 650 turbos - Wagner IC - 200 cells cats - Milltek cat-back - Hotchkis bars - Bilstein B16 - MTM Wheels - oem coolant cap
TechNick
Re: Pressure relief valve : how does it work?
Post by TechNick » Sat Nov 19, 2022 12:48 am
Just a one-way non-return valve, isn't it?
Presumably, a diaphragm of some description inside that permits air to travel in one direction, but not the other(?)
Classik
Post by Classik » Sat Nov 19, 2022 8:26 am
Hi Technik,
I've got 2 sets - 4 in total- of those, and except if they are all broken (could be!) they let air go through both ways at standard pressure. So no, it's not a non-return valve, although there's one in the ventilation system (part #16).
Post by Shoppinit » Sat Nov 19, 2022 10:55 am
It's a pressure limiting valve. It'll allow flow in both directions at low pressure, but close when the pressure (or vacuum rather) increases beyond a certain point, presumably to prevent the turbos trying to suck the contents of the crankcase into the intake. I bet they're dead cheap. Just replace them all and forget about them for a decade.
Classik
Post by Classik » Sat Nov 19, 2022 1:57 pm
Thank you Shopp. So what you're saying is that if I close one end and apply vaccum on the other end, it should block the flow when releasing the blocked end. Will try tonight
Post by Shoppinit » Sat Nov 19, 2022 2:10 pm
I think it probably depends on air flow, which isn't the same as pressure, but related. I could be wrong. I'll be interested to know what your experiments give.
Maybe if you use a vacuum cleaner, that might give you the airflow necessary. Assuming you've got a good one like a Miele. :)
Post by Shoppinit » Sat Nov 19, 2022 2:34 pm
It might not even cut the flow entirely. Given the name, it could be that it just limits the flow which would make testing it more challenging.
Classik
Post by Classik » Sat Nov 19, 2022 10:44 pm
Kind of matches my 'findings' : with the vacuum cleaner put on the side of the valve, I can see the piston moving up (actually down when the valve is mounted..), but the flow is definitely not cut. It feels like more restricted but honestly hard to tell without real measurements.
Honestly it's still a bit of mystery to me as to what's the main purpose of the thing and how it operates at different engine conditions (idle, boost, deceleration).
Classik
Post by Classik » Tue Dec 06, 2022 12:31 am
Users browsing this forum: Majestic-12 [Bot] and 125 guests
