Hi all,
What the view on Vagcom/VCDS versus OBDeleven?
I need to do a couple of reset functions, DTC memory of ECU Number 2 and reset of drivers seat memory.
Would welcome people's opinions.
Thanks!
Vagcom/VCDS or OBDeleven
Re: Vagcom/VCDS or OBDeleven
hi
i have used both, Vagcom is really good if your gonna get indepth, its easier to use than obdeleven, i have obdeleven to check fault codes etcs, can do a lot if not everything that Vagcom can do just a little harder to navigate. whats up with your seat, i lost all adaptions for my drivers seat when i was having battery problems. i moved the seat to the end of each axis eg forward/back u/down and that sorted it. it need to relearn its limits
Paul
Paul
Thanks, good info.
The memory function doesn't work on the drivers side (works fine on the passenger side). From what I've read the seat needs a reset.
(I've tried the all the way forwards, up, back, down thing - no joy)
- stuartbarriskell
I'm also interested in buying a "reader".. the one that I've been recommended is under 40 quid, Where's best to buy the Vagcom from
Stu
Sent from my SM-G998B using Tapatalk
Stu
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
21 BMW S1000RR Sold
04 ZX 10R Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
i know this is silly question but you havent got the memory seats switched off on the buttons cause my wife has a habbit of knocking the on/off button
Users browsing this forum: IanH755 and 54 guests
