All the warning lights!?!?!
super7
Post by super7 » Sat Sep 03, 2022 2:11 pm
Just been having a drive round town and out of nowhere got loads of warnings all at the same time.
- Parking brake!
- Sport differential: system fault
- Start-stop system: system fault! Function unavailable
- Stabilisation control (ESC/ABS): fault! See owner's manual
- Parking brake auto release: not available
Switched the car off for 20 mins and left it and they’re still there. Any one had it before or got any ideas?
Could just be the codes need clearing off with a machine and wouldn’t reoccur.
Just seems odd all those bits going together…
Daveperc
Re: All the warning lights!?!?!
Post by Daveperc » Sat Sep 03, 2022 6:59 pm
Sounds like the usual symptoms of the battery failing.
Good luck
super7
Post by super7 » Sun Sep 04, 2022 6:23 pm
Good luck
Thank you! Hopefully that’s it. So replace battery, clear the codes then should be sorted?
Rings78
Post by Rings78 » Mon Sep 05, 2022 1:46 pm
This happened to me a few years ago. It was a wiring loom near the front bumper that needed replacing. Not hugely expensive if memory serves.
rs64u
Post by rs64u » Sun Sep 11, 2022 9:04 am
I had the same issue and it was the ABS pump module and it’s a bit expensive .
Rich85
Post by Rich85 » Tue Sep 13, 2022 1:53 pm
Might be best seeing if you can see what’s logged via a reader
Had similar issues on an C7 A6 allroad and turned out to be an ABS sensor
rs64u
Post by rs64u » Mon Oct 10, 2022 1:28 pm
Is your problem solved ?
super7
Post by super7 » Fri Oct 14, 2022 11:41 am
It solved itself after a few days. Got a code reader and ended up not having to use it. Sorry haven’t been on the forum for a while!
