Intermitant limp mode
777spectre
Post by 777spectre » Sun Aug 28, 2022 7:46 pm
Hi people i have an intermittent limp home mode issue qith my b7 rs4 for a month or so now and im not having much luck sorting it , it seems to happen only when warm and usually at start up or pulling away under light throttle the EPC light comes on and DSC if i turn ingnition off and on again it runs fine ,ive visually checked the throttle body plug and fitted a new plug , and checked the throttle pedal no obvious faults seen , the fault codes i have at the moment is p1545 throttle control valve system malfunction, ive tryed to reset the throttle valve and no luck , i then replaced the throttle body with a corvett version still fault occurs im not sure its the throtrle pedal but its my next port of call really, as its intermittent or is it possibly an ecu issue has anyone had similar problems any suggestioms qould be appreciated
eliano
Re: Intermitant limp mode
Post by eliano » Fri Sep 02, 2022 5:44 pm
Check under the scuttle panel , ECU is prone to water ingress
RS4 B7 Saloon, Phantom Black , Billy B14 and ss+ arbs, LED's all inside & out with Dectane LED tailights. deflap, MRC Stage 2, Carbon Clean, no pre-cats, Custom Blueflame non res cat back exhaust, AP Racing Discs, alcantara wheel, gaiter and handbrake retrim, R8 gearknob, red belts (anyone want to swap belts for black ;-/ ) 438PS
777spectre
Post by 777spectre » Fri Sep 02, 2022 5:59 pm
Hi mate thanks for the reply the car doesnt see rain much , but i did check anyway it all seems fine , i have just fitted a new used throttle pedal and it didnt fault today but im not convinced its fixed 🤔
777spectre
Post by 777spectre » Sat Sep 03, 2022 11:44 am
Yep still not fixed ....so its not throttle body, throttle pedal , throttle body plug , im gonna have another look at the wiring or maybe a ecu problem anyone had any ecu problems ?
irishmike
Post by irishmike » Wed Sep 07, 2022 10:57 pm
It's it only that one code you are getting?
I had a similar issue and it came down to an ECU problem, but I think I had different error codes.
Then there are two ECUs in a Master/Slave setup so needed both replaced.
I was lucky to have an aftermarket warranty to cover most of it, not cheap....
Sent from my HD1903 using Tapatalk
Covkiller
Post by Covkiller » Thu Dec 01, 2022 10:06 pm
I had exactly this problem and bought a new throttle body and had it fitted by Audi. Problem fully resolved.
What's with the corvette version and is it new?
TS811
Post by TS811 » Tue Jun 27, 2023 9:10 pm
I'm having this problem on my 2008 RS4. Took it to the dealer who started by replacing the throttle body connector, to no avail. They say the next step is to replace the throttle body but that it's part of the intake manifold and the whole IM needs to be replaced. Yet I'm reading here that others have replaced only the throttle body..?
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], Majestic-12 [Bot] and 77 guests
