Hi,
Anyone got any experience with Coding out TPMS via VCDS ? its my first RS4 B7 and whilst the car is fantastic .....the TPMS is driving me nuts.
VCDS code out TPMS
Re: VCDS code out TPMS
Hi,
I've just done this using OBDEleven.
These posts might help:
- viewtopic.php?f=35&t=108002&p=651686&hi ... 12#p651686
- https://www.audiworld.com/forums/rs4-b7 ... 7-2950925/
From memory, you need to go into the instrument cluster and reduce the channel with the TPMS by 512.
Thanks highrise, will take a look
Quick update : For anyone wanting to remove TPMS via VCDS i followed the instructions below and it worked for me.
To disable TPMS – go to 17 – Instruments and then go to the Adaptation module.
In the Adaptation module, switch to Channel 061 then subtract 512 from the number that is displayed. Save and Exit.
Users browsing this forum: No registered users and 95 guests
