Detailed RS engine specs anybody?
bettonracing
Re: Detailed RS engine specs anybody?
Post by bettonracing » Fri Apr 04, 2003 8:49 pm
as if it's his fecking forum
That's why I asked nicely.
ooops sorry if we hi-jacked your post
Thanks for being professional about it even though "it's not my fecking forum".
I'm trying to get the specs because there are a few of us here in the states looking to build a race car (about 1 & 1/2 yrs) using either the RS4 or RS6 engine. I'm trying to do some research. Can I proceed without any animosity please?
Andiroo
Post by Andiroo » Fri Apr 04, 2003 9:06 pm
Hey Kurt, just our British sense of humour - chill mate [img]images/graemlins/wink.gif[/img]
Even with the good availability of RS6's in the UK ( [img]images/graemlins/roflmao.gif[/img]) you will find the RS4 a better bet for a base engine (race or otherwise) - in fact some S4's are kicking out over 500bhp using RS4 turbos and bits, and they are even available direct in the US [img]images/graemlins/laugh.gif[/img]
Try to locate an RS6 short block would cost you a mint [img]images/graemlins/frown.gif[/img] - what parameters do you have to work with?
Andiroo
Previous :RS4 B5 (Noggy Babe), 934 GT2, 996 Cup.
WIP :to be advised.....
RS246 Live! CLICK HERE for details of the big RS246 event for 2008 **And how it died on it's arse**
bettonracing
Post by bettonracing » Fri Apr 04, 2003 9:25 pm
I'm not too worried about the $$$ because our sponsors have faith in us. Our plan of attack (on the sponsors) is to also use the aspect that cars in the US are 'drifting' towards bigger engines (however more efficient) and using the V8 as a showboat may receive alot of publicity (small car. Golf. mid engined if all goes well) = good for sponsors.
Also we're looking for a little more hp than that. Bigger engine = make hp easier = reliability. Plus we'd be machining alot of the internals.
There are still a few more factors which will help decide which engine to use (exhibition car? race league? etc) so I'm still deep in the research stages. Plus if the 6 looks sturdy enough we'll use it. That is the team's overall first preference ('fitment', $$, popularity thus far, etc).
Thanks for the adv though. [img]images/graemlins/thumbs.gif[/img]
Andiroo
Post by Andiroo » Fri Apr 04, 2003 9:39 pm
[img]images/graemlins/wink.gif[/img] Why not go the easier and cheaper route, all easily available in the US ;
Boss 429 cu in all alloy block/heads, titanium rods & pistons, full floating pins, Dyers 8-71 blower with Enderle Fuel Injection etc etc ...............
Must be good for a little bit more than 450bhp [img]images/graemlins/roflmao.gif[/img]
[img]images/graemlins/roflmao.gif[/img] [img]images/graemlins/roflmao.gif[/img]
So do you have any criteria for cc (or ci) turbo/non-turbo?
Andiroo
bettonracing
Post by bettonracing » Sat Apr 05, 2003 2:48 am
Why not go the easier and cheaper route, all easily available in the US:
I've actually built a few of those. (not exactly your specs but brute force engines).
Reason why not: I think I failed to mention that this car is gonna take corners too. [img]images/graemlins/roflmao.gif[/img] [img]images/graemlins/icon_lol.gif[/img]
And I'm hoping to actually make it around the entire track (gas).
We're looking towards the Khp. [img]images/graemlins/sekret.gif[/img] sshhhh....
(I'll probably get the crap kicked outta me for talking too much)
Those are the regulations that we're still checking out but the car is definitely gonna be a turbo (single). If we make it an exhibition car, it's gonna have no limits...
Depending on if we choose to race it in a few leagues, we might try to make it a little 'universal' and do minor mods to change to each series. SO as of now there are no specific limitations (hint, hint) but all we have as of now is the car. We're also going through it to find out how hard each project would be to help with the decision. U know of the Dahlback Golf? Major influential factor... (hint, hint). Also we built a corrado that was notorious at the street 'confrontations' (we don't promote street racing... [img]images/graemlins/sekret.gif[/img]). i.e. until the cops saw it spitting a 10" fireball at a stop light one night. Just before the 65ft 'laying a drag'. Needless to say... [img]images/graemlins/ban.gif[/img]
Another major influence...
Riz_RS4
Post by Riz_RS4 » Sat Apr 05, 2003 10:08 am
The RS6 uses a Bi-Turbo configuration to achieve 450bhp, are you sure a single turbo will be able to replace this much power output or are you looking to use a industrial turbo unit?
Image I`m just a hardcore petrol head :)
bettonracing
Post by bettonracing » Sat Apr 05, 2003 3:13 pm
relatively industrial sized . +psi if nec. Will be custom made. One of the guys is an aero eng. specialty = compressors. He 'designed' the turbo for the corrado. 1bar @ 3.8krpm; 2.2 bar @ 8krpm. Nicknamed the 'freight train' (from the turbo whistle and the tq).
bettonracing
Post by bettonracing » Sat Apr 05, 2003 3:15 pm
Anybody come up with specs yet? Anything?
PhilT
RS246.com
Post by PhilT » Sat Apr 05, 2003 3:18 pm
Have you had a look at this?
Post by Dave » Sat Apr 05, 2003 3:36 pm
This is all I can find in the manual:
V8, spark ignition, 5 valve technology, bi-turbo, two light alloys cylinder heads, three inlet valves, two exhaust valves, four overhead camshafts (DOHC).
Displacement : cm3 : 4172
Max Output kW (bhp) at rpm : 331 (450)/5700-6400
Max Torque, Nm at rpm : 560/1950-5500
Bi-turbo, fully electronic, sequential multi-stage injection system with air mass measurement, mapped ignition, stabilising high pressure distribution, camshaft adjustment, cylinder bank selective exhaust temperature regulation and co-ordinated engine momentum management.
Emission Control System:
Two curved pipes with air isolation feature, two initial stage catalytic convertors located close to the engine, stage catalytic converters, two primary catalytic converters, cylidner selective lambda control with two heated lambda probes.
Does that help at all?
Now waiting (again!): Misano RS4 B7 Saloon.
wazza
Post by wazza » Sat Apr 05, 2003 3:56 pm
Is this any good?
Paul
bettonracing
Post by bettonracing » Sun Apr 06, 2003 5:58 am
Thanks.
