Snapped timing belt - RS4 B5
2.7 V6 30v biturbo - 380 bhp
hsf
Post by hsf » Thu Mar 10, 2022 5:33 pm
Well....
After fully building the engine, with forged rods, JE pistons, upgraded valvetrain , bigger turbos etc , i have made around 1400 km of a break in period.
When finished, corrected some minor bits , such as oil leaks and installed the tfsi coils (thetuner conversion) and bosch ev14 950cc injectors.
Went for mapping and in the middle of a mapping session the engine shut down.
Result : Broken timing belt. ( brand new gates blue rpm installed with rebuilding ).
Already dismantled engine and conclusions:
- Most of the engine valves are bent ( ferrea competition )
- Not a single problem found on pulleys , waterpump etc ( all of them are new )
- Slight marks on pistons that won´t cause any problem later.
Other than that, the chamber gives me the idea of a very lean mixture, also the exhaust valves were "rought" on the surface, indicating too much heat.
Did the belt snap because of overtension ? It seems that the supposed 15nm of tension wasn´t applied.
Nige_RS4
Re: Snapped timing belt - RS4 B5
Post by Nige_RS4 » Sat Mar 12, 2022 12:44 pm
That's not good - was the belt new? I guess it could be a lot works i.e. bent rods or a hole in the block.
Why did you chose to use an aftermarket belt rather an OEM Audi one?
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
hsf
Post by hsf » Mon Mar 14, 2022 5:17 pm
Well,
Don´t have an explanation for that.
Always knew Gates as timing belts company, and saw a vast amount of tuners using these gates rpm belts :)
There are many tuned S4´s and RS4´s using this exact belt..
Brand new when i bought it, it has the break in quilometers :)
ViktorP
Post by ViktorP » Fri Sep 16, 2022 7:43 am
I will listen too. A similar situation
