With the car sitting on CTS links and on dynamic setting still no rubbing.
Thanks for info, interesting how it would look on stock rs6 only with drc (no coils) and will it needs any spacers?Bruisernz wrote: ↑Fri Feb 18, 2022 8:50 pmFerrada FR2 22x11"
www.ferradawheels.com They have some pretty cool options for RS cars with brake clearance.
Some say that 5mm spacers only needs in a front and not necessary for rear, what about rubbing tires because 22 inch is very huge and what happens when you extra load something heavy for example like traveling somewhere long distance, will it not be a problem?Bruisernz wrote: ↑Sun Feb 20, 2022 8:46 pmThe wheels only needed a 8mm spacer for the brake clearance, they offer two offset choices, 22x11" 20p (needs spacer) and 22x11" 10p, doesn't need spacer.
We presumed both fitments cleared the brake, but found out the hard way the spacer was required. The 22x11" with the 15mm spacer, to give the very aggressive look was the customers
choice, so doesn't need to be that aggressive.
https://ferradawheels.com/product/ferrada-fr2
https://ferradawheels.com/pf/audi-rs6-fr2-matte-black/
Ok thanks for that information, so if I don’t want spacers I can get in a front 10p and on a back 20p.
I got some information that it can be rubbing if you load a lot in a trunk, maybe 21 inch is just a right solutionBruisernz wrote: ↑Thu Mar 03, 2022 12:29 amSteel version, i have just ordered the wheels, so can give you an update once they arrive to give you exact fitment.
The 10p front I am planning on machining 2-3mm to give a 12-13p offset to best suit the fitment. Also ordered front upper camber bushes to allow some extra front camber to give more clearance also.
Users browsing this forum: Google [Bot] and 70 guests
