AUDI RS6 C7.5 with C8 22” x 10.5” ET19 GENUINE ALLOYS
Bruisernz
Re: AUDI RS6 C7.5 with C8 22” x 10.5” ET19 GENUINE ALLOYS
Post by Bruisernz » Fri Feb 18, 2022 3:09 am
I run a business that fits wheels an tyres, the most aggressive fitment we have done on a RS6 is 22x11" 20p offset with a 15mm spacer. 285/25/22.
With the car sitting on CTS links and on dynamic setting still no rubbing.
Tadass910
Post by Tadass910 » Fri Feb 18, 2022 4:42 pm
What kind of rims this car has?
Bruisernz
Post by Bruisernz » Fri Feb 18, 2022 8:50 pm
Ferrada FR2 22x11"
www.ferradawheels.com They have some pretty cool options for RS cars with brake clearance.
bowesta66
Post by bowesta66 » Sat Feb 19, 2022 11:10 am
That’s is very reassuring to hear as doing this type of upgrade is expensive.
Thanks for the info 👍🏻💥💥
Tadass910
Post by Tadass910 » Sat Feb 19, 2022 1:11 pm
Ferrada FR2 22x11"
Thanks for info, interesting how it would look on stock rs6 only with drc (no coils) and will it needs any spacers?
Cant find that rims on their website I find only CM2 https://ferradawheels.com/product/ferrada-cm2/
Bruisernz
Post by Bruisernz » Sun Feb 20, 2022 8:46 pm
The wheels only needed a 8mm spacer for the brake clearance, they offer two offset choices, 22x11" 20p (needs spacer) and 22x11" 10p, doesn't need spacer.
We presumed both fitments cleared the brake, but found out the hard way the spacer was required. The 22x11" with the 15mm spacer, to give the very aggressive look was the customers
choice, so doesn't need to be that aggressive.
https://ferradawheels.com/product/ferrada-fr2
https://ferradawheels.com/pf/audi-rs6-fr2-matte-black/
Tadass910
Post by Tadass910 » Tue Feb 22, 2022 5:01 pm
Some say that 5mm spacers only needs in a front and not necessary for rear, what about rubbing tires because 22 inch is very huge and what happens when you extra load something heavy for example like traveling somewhere long distance, will it not be a problem?
Bruisernz
Post by Bruisernz » Tue Feb 22, 2022 9:58 pm
Ferrada wheels say yes only a 5mm is required, but they also have 10p that requires no spacer.
Tadass910
Post by Tadass910 » Tue Feb 22, 2022 10:23 pm
So 10p also in 22x11? Sorry I am noob in those numbers
Bruisernz
Post by Bruisernz » Tue Feb 22, 2022 11:57 pm
Yes so they do a 22x11" in either 10p or 20p, i have ordered 10p for the front (for brake clearance) and 20p for the rear to avoid any chance of rubbing.
Tadass910
Post by Tadass910 » Wed Feb 23, 2022 10:40 pm
Ok thanks for that information, so if I don’t want spacers I can get in a front 10p and on a back 20p.
P.s your car has ceramic brakes or simple steel?
Bruisernz
Post by Bruisernz » Thu Mar 03, 2022 12:29 am
Steel version, i have just ordered the wheels, so can give you an update once they arrive to give you exact fitment.
The 10p front I am planning on machining 2-3mm to give a 12-13p offset to best suit the fitment. Also ordered front upper camber bushes to allow some extra front camber to give more clearance also.
Tadass910
Post by Tadass910 » Mon Mar 07, 2022 4:54 pm
I got some information that it can be rubbing if you load a lot in a trunk, maybe 21 inch is just a right solution
Bruisernz
Post by Bruisernz » Mon Mar 07, 2022 11:26 pm
It can rub with a 21" also, the overall diameter of a 285/30/21 tyre and 295/25/22 is less than 1% difference.
With the CETE air control its not an issue as can customise the height to ensure no rubbing.
bowesta66
Post by bowesta66 » Tue Mar 22, 2022 8:44 am
Omg
I don’t know about the rest of you who have done this conversation but I’ve had to take mine off and put them up for sale.
What a disappointment major rubbing on both fronts unsafe to be honest.
I really like to drive my car and this Modification hasn’t been suitable on my car.
Anyone else had the same problems 😔
