The gear lights of doom!!!
Foxmeister
Post by Foxmeister » Mon Dec 27, 2021 7:20 pm
So i am finding RS6 ownership is a lot like a Mondeo ST220 i had a few years back, when i was on the forums and there were listed faults etc, it wasnt a case of "if" but "when" you get to experience them :boohoo:
So a couple of nights ago i started up and had all the lights on the dash for the gearbox, after driving away slowly it was clear something wasnt right so i stopped and done the ole off and on, it cleared and all was well again... until tonight, just went to nip to shops and when pulling away it wasnt going to change gears, revs kept climbing and even trying the paddles it wouldnt shift up. Again i turned off and on and its cleared, for now. Have noticed gear changes have been more harsh lately also, is all this pointing towards the F125 switch?
I dont have VCDS currently, cue everybody telling me i should have it, i know i know, and i'll aim to get it ordered now but its not the ideal month for this pi$$ but hey ho
So am i right in thinking these switches are becoming hard to get hold of? Does anybody have a part no for it if this is the problem? I'll add that the box has previously been done but not in my ownership, so not sure if they had the switch done then, probably unlikely as the car has been trouble free until now, thats what i get for leaving it standing for about half a year! :roll:
Re: The gear lights of doom!!!
Post by Shoppinit » Mon Dec 27, 2021 7:32 pm
I don’t think there’s a switch shortage problem, but your issue sounds more like a mechanical one. You might want to check your ATF level.
Foxmeister
Post by Foxmeister » Mon Dec 27, 2021 8:05 pm
Really Shop? Even though the turn off and on clears it all? I thought it would point towards the switch
I'll see what i can do, its due a service and belts anyway so plan to get that done soon, need to see if i can get the fluid checked somewhere as i dont imagine its an on the floor job?
Post by Shoppinit » Mon Dec 27, 2021 8:15 pm
You said revs kept rising so I assumed it was slipping but maybe I’m reading you wrong.
Foxmeister
Post by Foxmeister » Mon Dec 27, 2021 8:59 pm
Sorry mate, in my head it made sense but that’s just to me 😂
No what I meant with the revs was, when pulling away and it was in first gear, it normally climbs to around 3-4K and changes, it wasn’t doing that, just continually climbing and revs still climbing, there wasn’t any slipping tonight
Although In saying that, the first time it happened a couple of nights ago, it definitely felt strange, as if it wasn’t properly selected in gear as it wasn’t pulling as sharp and felt like it was about 60% pulling compared to normal but that was right up through the range (was only a short drive leaving a street) but it wasn’t slipping as such
As said, when I have stopped and restarted the car, it drives fine then, gears are normal, selects as normal etc, just seems to be a hiccup when it’s left cold currently so I’d like to catch it before it gets worse
I’ll get VCDS ordered as that will be the best route I’m sure to see what it’s saying, I’ll update once I get that but might need help as I’ve never used it before
HPsauce
Post by HPsauce » Mon Dec 27, 2021 9:51 pm
Sounds like standard "limp mode" which is usually third gear. Moves off using the TC to slip initially and then just pretty much locks up so revs match speed.
In a car with a lesser engine you'd notice it being really tardy, but you have loads of torque so it just feels a bit slower than normal.
You DEFINITELY need VCDS.
Mark-RS
Post by Mark-RS » Mon Dec 27, 2021 10:10 pm
Maybe if we buy 2 gearboxes we will get a discount ? :D
Post by Shoppinit » Mon Dec 27, 2021 10:12 pm
What HPsauce said. Except I think it sticks in fourth.
alexmac
Post by alexmac » Mon Dec 27, 2021 10:29 pm
Mine did this last week, stuck in one gear and couldn’t change. Turned car off and on and it’s been fine ever since.
Plugged VCDS in today and the only error that came up for the Transmition was
1 Fault Found:
18243 - Pressure Control Valve 5 (N233)
P1835 - 35-10 - Short to Plus - Intermittent
airtite
Post by airtite » Tue Dec 28, 2021 9:48 am
i would check atf 1st, the harsh gear changes when NOT in PRNDS all lights on points more to mechanical
Foxmeister
Post by Foxmeister » Tue Jan 11, 2022 4:17 pm
Update
Found quite a substantial amount of water on various footwells over festive period, are the gearbox TCU wiring or anything under the carpets? Likely this is causing my issue?
Currently removing said water and will probably have to remove carpet fully to dry properly
Post by Shoppinit » Tue Jan 11, 2022 4:18 pm
TCU and CCM.
Get them out, open them, bathe them in isopropanol and dry them asafp.
Foxmeister
Post by Foxmeister » Tue Jan 11, 2022 9:48 pm
Will do, used a wet vac today to remove the excess but there’s plenty soaked into the underlay, seats etc out tomorrow to remove carpet
Any recommendations for the isopropanol and where to get it?
Post by Shoppinit » Tue Jan 11, 2022 10:28 pm
I bought some of this recently. Seems as good as any I’ve ever used:
https://www.amazon.co.uk/gp/aw/d/B082XQ4W4R
