Squealing Brakes - RS4 B9.5 2021
Tell me i'm not the only one...
(hearing its a common issue across all RS models...?)
Re: Squealing Brakes - RS4 B9.5 2021
So bad that I changed to APR brakes on my RS3 and RS4.
TX.
Sent from my BBB100-2 using Tapatalk
TX.
Did you change discs and pads? 1600miles in and mines been squealing since day one. Taken to dealer twice, had them deglaze under warranty but the squealing remains - they now say nothing can be done and its a common issue on all RS models which they aren't obliged to fix under warranty...Terminator_X wrote: ↑Thu Nov 25, 2021 3:40 pmSo bad that I changed to APR brakes on my RS3 and RS4.
TX.
The entire setup or just discs/pads?Terminator_X wrote: ↑Thu Nov 25, 2021 3:40 pmSo bad that I changed to APR brakes on my RS3 and RS4.
TX.
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
^^ the whole front brake system yes on the 4. Front and back on the 3!
TX.
TX.
Had all the RS4s from the B5
Never really had an issue with squeaky brakes but it did pop up now and again but a series of at least 10 hard almost stops from 70 to 10 mph would clear it up
It is usually cause by slow stop start driving building up pad material on the disks
The hard braking method will remove any pad deposits on the disk
Worst case try skimming the disk
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Did that solve the problem?Terminator_X wrote: ↑Thu Nov 25, 2021 4:31 pm^^ the whole front brake system yes on the 4. Front and back on the 3!
TX.
Users browsing this forum: No registered users and 7 guests
