F125 Switch or TCU - or something else?
Duke Thrust
Post by Duke Thrust » Fri Nov 12, 2021 12:29 pm
Hi all,
Recent RS6 purchase here, 2003 Daytona Grey - loving it so far.
But... Gearbox niggle has surfaced. It's done 130k and had a full gearbox rebuild at 90k. Gearbox oil and filters changed by the previous owner less than 1k ago.
A couple of times now just after starting from cold all the PRND gear indicator on the dash has lit up, a switch off and back on and the problem has immediately resolved itself (seems to be after the car has been standing for a few days on both occasions).
Some searching on this forum suggests it could be the F125 switch or the TCU itself, but wanted to get people's thoughts.
Thanks!
Re: F125 Switch or TCU - or something else?
Post by Shoppinit » Fri Nov 12, 2021 12:36 pm
Could be a number of things. Hard to say without seeing what the fault codes are.
Does it go into fault after starting or when you put it into gear?
srichards
Post by srichards » Fri Nov 12, 2021 12:39 pm
When was the 12v battery last changed? A dodgy one of those can cause all sorts of mayhem as well.
Is it kept outside or in a garage?
Duke Thrust
Post by Duke Thrust » Fri Nov 12, 2021 1:37 pm
It's not showing any codes at the moment, from the transmission at least (two engine mount codes, looks like they've failed)
It goes into fault after putting it into gear, both occasions it's been into reverse first.
Duke Thrust
Post by Duke Thrust » Fri Nov 12, 2021 1:38 pm
The battery is pretty new, last owner changed it, I think in the last year or two.
It's kept outside.
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 12, 2021 1:40 pm
On the surface of it, those are the symptoms I had when my F125 switch needed replacing, but as Shopp says, you need to verify/check the actual error code via VCDS.
Post by Shoppinit » Fri Nov 12, 2021 2:18 pm
Yeah. There should be codes stored in the TCU if you've had the PRNS on the dash.
Duke Thrust
Post by Duke Thrust » Fri Nov 12, 2021 5:33 pm
Thanks guys, I'll wait for it to happen again and see if it records a code that time- I'm just using a standard reader (that will talk to gearbox/ABS etc etc) not Vag Com (sorry if that's the wrong name), as I say, no codes so far.
Post by Shoppinit » Fri Nov 12, 2021 5:34 pm
It's possible that your reader won't be able to read the manufacturer specific codes of the TCU. Where abouts are you? Maybe there's someone near you that can scan the car for you.
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 12, 2021 5:36 pm
I'm 90% sure that a standard OBD reader won't read those TCU errors.
Post by Shoppinit » Fri Nov 12, 2021 5:37 pm
Also, since the defect is effectively self clearing, then you'll have an intermittent or pending fault code which might not be displayed by your reader, even if it can talk to the TCU.
Duke Thrust
Post by Duke Thrust » Fri Nov 12, 2021 6:03 pm
Ah, okay, makes sense.
I'm in Cheltenham.
On the F125 switch, reading this forum the part number (seems to be) 01L 919 821 B, when I google it the results come up as 01V 919 821 B
Is that correct?
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 12, 2021 6:09 pm
Looks like there's still stock too, should work out about 180ish quid
Duke Thrust
Post by Duke Thrust » Fri Nov 12, 2021 6:29 pm
Thanks - from Audi?
(Searching reveals two different connector types, one round and one oblong - both seem to have ten pins.
Mɐʇʇ
Post by Mɐʇʇ » Fri Nov 12, 2021 6:31 pm
Yes.
Users browsing this forum: Bing [Bot], Google [Bot], srichards and 98 guests
